Hk 206 air filter box.
08.05.2020 20:02 # 1
dejawu1978
hi aleyküm ..beyler something i will consult you, there is no part in the car that I have marked in the picture in the car, it is empty in my car ... would it be a problem if i use it without this ... (Track number 9)
08.05.2020 20:02 # 2
teacher, its purpose is to filter the foreign matter into the air filter - stone - water etc. to avoid direct contact. to stay open, water from here etc. wetting of the filter will cause the vehicle not to absorb comfortable air and cause problems.
http://www.peugeotmarket.com/peugeot-206-14-benzınlı-hava-fıltre-dozoru-2006-2013,pr-1913.html
sonerkyl 2016-11-22 13:47:18
08.05.2020 20:02 # 3
iammanover
I think there is an open air filter in the vehicle, there is an air canister in the place where you call it empty, as the soner says, the tip goes to the left fenders and takes the orig. I recommend you to put
08.05.2020 20:02 # 4
dejawu1978
no open air filter, no where you know empty ... thanks for the cvp ... Thumbs Up
08.05.2020 20:02 # 5
samet206
During a repair, they were dismantled, not replaced or damaged. Or, as their other friends say, an open air filter was installed, so they were disassembled then it remained. Said part has a pipe extending into the left fender, it curls from below and enters the air filter box. This is the system I know so that it does not.
08.05.2020 20:02 # 6
dejawu1978
[QUOTE = sonerkyl] my aim is to filter airborne foreign matter, leaf - stone - water, etc. to avoid direct contact. to stay open, water from here etc. wetting of the filter will cause the vehicle not to absorb comfortable air and cause problems.
I ordered the dedigniz product yesterday, I hope it does not require an extra pipe apparatus .... Wink
