Hk 2008 semi-automatic transmission problem.
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
08.05.2020 21:28 # 1
akosuk59
Greetings Friends,
2008 model - In the Suv model of 2014, we have serious problems with the gear shifts in the semi-automatic transmissions. Gear Shifts are felt too much. Also, the vehicle cannot adjust its speed.
Are there friends who have the same problems on the subject? is there a solution for this? If there are friends who know, I would be glad if they can help.
I also shot a video on the subject, I think it is more understandable.
I'll be happy if you can help me.
good forums
08.05.2020 21:28 # 2
talip206
Good afternoon, unfortunately, this is the general problem of semi-automatic transmissions. Regardless of which brand model, there are similar problems.
I think go to the authorized service and install the updated software for the transmission. There are those who say that it is much better with the current software than before. Also, have the printing pad checked.
Peugeot is too late to switch to the new eat6 and eat 8 transmission. I like the previous case 2008 very much, but just because of this transmission, I get the options. The new transmissions are Japanese aisin production and almost flawless.
talip206 2020-03-02 13:25:29
08.05.2020 21:28 # 3
akosuk59
Thanks for the answer, yes unfortunately I couldn't think it was so problematic. My friend has a new series, as you said, flawless. not felt. but the 2014 series is a disgrace: S
28.06.2021 11:26 # 4
Mozturk52
I have a 2017 model 2008 and I have the same problem. It started making noise when shifting gears. I took it in for service today. It has an extended warranty. I will write if there is a result and solution..
