hitting sound from the front left
08.05.2020 15:45 # 1
asil16
friends, I changed ten springs, I had a 3.5mm spring last day, now I have a little curve on the left left, I wonder if the sound of sound is coming up, amorcum exploded? has the emblem ??
08.05.2020 15:45 # 2
sahin-peugeot
Hello,
When the sound is normal, my vehicle is mechanically related to its originality, it is likely to disrupt other places in connection with each other, it will lower the spring, damage the front gear and shock absorbers. I look at the car of most of them, there is a two-finger distance between the ground, it falls into the pit hardly.
If you send a picture of the malfunction lamp that may be related to the brake, I can speak clearly,
Good luck with
