Hiss sound coming from the 406 engine part
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 19:42 # 1
ozkank
Well, good day everyone used to give my computer a hissing sound at first start, but this sound was not understood without opening the hood yesterday after the car passed a little hard from the car, this sound was heard to be heard from inside the vehicle. can cause my car gasoline lpg (I will add the evening video)
sample video
08.05.2020 19:42 # 2
burakipek34
I have the same problem, did you find a solution?
08.05.2020 19:42 # 3
sozuak
The subject is old but it is a sound called Westinghouse hose coming from the inlet manifold and going to the brake servo and a sound you can hear as a result of tearing the brake diaphragm. If you have low braking performance besides this sound, check / have the hose checked. I was touching a hot part of the engine and making a molten leak. Let me unscrew the hose and see if it's hard plastic, or is there a crack? I was stopping the car hard.
In addition, irregular idling problem may arise as the engine will breathe.
