High speed battery lamp?
08.05.2020 17:43 # 1
Aziz
For 2 days, after 5 thousand cycles, the battery lamp blinking on the instrument panel is the reason for friends.
08.05.2020 17:43 # 2
candanxyz
I know normally if he does it when he enters the cutter.
08.05.2020 17:43 # 3
Aziz
no cutter starts blinking after 5 thousand cycles at 6501 rpm :) blink as well as warning
08.05.2020 17:43 # 4
fatihgg
look at the charge dynamo
08.05.2020 17:43 # 5
candanxyz
look, I found an answer like this.
I think it will most likely be related to your fan belt ...
I think there is a problem with the V-belt. Since it cannot hold the pulleys completely, it can not charge instantly as it performs some kind of skidding on the pulley and turns on the light. It clings and turns off the light when charging starts again.
08.05.2020 17:43 # 6
Aziz
Charger and V-belt, any other noted?
