High Headlight Problem?
08.05.2020 17:06 # 1
kayahan84
I just joined your Sa Friends Search. & Nbsp; Let me talk about a problem in my car & nbsp; & nbsp; I am happy if my friends with knowledge of & nbsp; s help. My car 205 Model 206 1.4 hdi Sporty My problem is this; Even though I turned off the headlights of the vehicle, the high beams do not turn off and remain on constantly. Yesterday I showed the auto electrician here & nbsp; & nbsp; the front & nbsp; on the hood & nbsp; next to the battery, the bsi (fuse plate) said rotted water, could this really be a problem? what else could it be and asked me 350 rubles of money on feast this was very boring :( I would be glad if my friends who understands throw a hand on the subject. > Note: The vehicle went into Full Computer test. The arms did not cause any problems.
08.05.2020 17:06 # 2
msk_sansal
hello 2 days ago same problem happened to me. I removed the socket of the main beam bulbs, I removed the headlights from its place, put it back, the bulb and the socket (plug) were fixed. & nbsp; the main beam bulb (s) faulty text on the screen has been removed and it has been removed ... >
1.6 hdi 2006 my technoplus vehicle
08.05.2020 17:06 # 3
muro_60
If you can, you can disassemble it, but if the bass is not water, it has oxidized, superficial cleaning will not be enough, you need to open it.
08.05.2020 17:06 # 4
kayahan84
fix kayahan84 2012-10-23 13:35:35
08.05.2020 17:06 # 5
kayahan84
[QUOTE = muro_60] as you can disassemble it if you can, but if the bass is nothing but water has taken oxide, it has to be superficial cleaning will not be enough. >
I thought that the relay could be stuck directly in my mind because it is recovering spontaneously from time to time du & nbsp;
08.05.2020 17:06 # 6
kayahan84
[QUOTE = msk_sansal] hello 2 days ago same problem happened to me. I removed the socket of the main beam bulbs, I removed the headlights from its place, put it back, the bulb and the socket (plug) were fixed. & nbsp; the main beam bulb (s) faulty text on the screen has been removed and it has been removed ... >
1.6 hdi 2006 technoplus vehicle
what exactly was your problem? I turn off the headlights completely, both left and right remain lit, I even remove the ignition key.
08.05.2020 17:06 # 7
msk_sansal
Sheikh. thanks my teacher
08.05.2020 17:06 # 8
msk_sansal
My problem is the first time I encountered it, so I started the car with something auto burned headlights. only the low beam signal was lit on the display & nbsp; panel, but when I saw it, it was lit long together. I thought, what is it? As soon as I clicked, they burned again. I said
it will not be so. I was restricted. I stuck one of them accidentally while inserting one of them, there is a hood opening device or the radiator from the hole in the hole there. Anyway, I had backups in the house, I bought them from the vehicle, I put them on, the setting is very bad, it shows an anya and a konya but it was long. & nbsp; the text on the screen has also been deleted. this is me.
08.05.2020 17:06 # 9
cey cey
In my opinion, take me to a beautiful master, show me what the room will do if the room gives the same price. I think, take off the headlights of the high beams until you get them done, continue with short & nbsp;
08.05.2020 17:06 # 10
muro_60
While this is the easiest long burning, check the relay one by one and then look at the relay & nbsp;
08.05.2020 17:06 # 11
kayahan84
[QUOTE = muro_60] this is the easiest long burning, seeing which one is the only one after the relays & nbsp; [/ QUOTE]
I couldn't fully understand what you mean. Can you explain a little more detail & nbsp; can you?
08.05.2020 17:06 # 12
muro_60
While the longs are burning, you know how there are relays in the cover box, one of them is going to go out when the high headlight is off.
08.05.2020 17:06 # 13
msk_sansal
[QUOTE = muro_60] As long as the relays are on, there are relays in the box, you know how one of them is going to go out when the high beam is stuck. let me look at the relay & nbsp;
08.05.2020 17:06 # 14
sanctuary35
The same problem is in my head right now. let me check the fuse panel and see if I can see a problem
08.05.2020 17:06 # 15
xmen
[QUOTE = sanctuary35] the same problem is on my head right now. let me check the fuse panel and see if i can see a problem [/ QUOTE]
my teacher did you solve the problem & nbsp;
08.05.2020 17:06 # 16
Halil samagan
tomorrow, as you said, let me have the insurance panel checked, it does not have long headlights, I do not always disturb my use, Halil samagan 2017-07-19 01:11:20
08.05.2020 17:06 # 17
Halil samagan
said the role of the headlight in the brain electricist birth these friends Halil samagan 2017-07-19 01:06:56
08.05.2020 17:06 # 18
[QUOTE = Halil samagan] THEY SAID FROM THE BRAIN I DID NOT RECOVER I HAVE TO KNOW THE PROBLEM IF I HAVE TO KNOW THE LONG HEADLIGHT, I LOCK EVERYTHING, I WILL REMOVE FROM BUMP <> >
first of all welcome to us. It is forbidden to write in capital letters as per the forum rules.
