high beam headlights
08.05.2020 18:39 # 1
okaNStarss
I had done it last night, my headlights remained hungry even when I stopped the car. Today, the longs are hungry again, the contact is closed, but only the longs are closed after a long time.
08.05.2020 18:39 # 2
Atix
Are your headlights automatic? When I understood it, if it did not happen to me automatically, but if somebody writes an answer, maybe I will get it.
08.05.2020 18:39 # 3
okaNStarss
No, it is not automatic, it burned itself, and it remained burned, then it was extinguished, by the way, although the battery was unplugged and retained, it continued to burn, then kwndi went out
08.05.2020 18:39 # 4
suppor
Maybe the signal arm may be broken, because there is a possibility because in the meantime, when the parks are open, the people will turn off after the pain will be closed, and the park will open the fog, then there is a look, the fog is closed, there are spontaneous parks, there is a defect in the arm, but who needs to clean it.
08.05.2020 18:39 # 5
ahmed206
My brother maybe it is about the follow me home you did later or daytime running lights?
08.05.2020 18:39 # 6
okaNStarss
In impossible fallow me fog, the room is not connected, daytime running lights are triggered and turn off when shorter. He didn't do anything today
08.05.2020 18:39 # 7
okaNStarss
[QUOTE = suppor] Maybe your signal arm might be broken, maybe because I am in the middle of nowhere, when the parks open, I have to see the people close to their head, then turn them off, open the fog in the park, have a look at the fog, closed the spontaneous parks, have a defect in the arm, do I need to clean it, but who does it? [/ QUOTE]
I wonder if I get rid of this problem
08.05.2020 18:39 # 8
yigit
My brother, first get well soon. I had the same problem. your situation is good, I waited 20 minutes and it did not go out again. then there is a fuse box under the hood of the vehicle. I hit it slowly with a hard object. fixed. I think he made a chassis. Then I took it to the industry. the master removed the two fuses in the fuse box and re-installed them. but my advice to you is to remove the fuses, just as I said, tap the fuse box a little, take it to the master if it doesn't improve. I have the same problem repeated for the second time. the master dismantled, i said i will disassemble it the vehicle has locked itself. I can not run. They came from the service. they did so. beware.
08.05.2020 18:39 # 9
yigit
(By the way, the length of the car was in the same condition as yours. I mean the contact is closed, I even got out of the car, locked the doors but did not go out.) I hit the fuse box: D)
08.05.2020 18:39 # 10
okaNStarss
Well, what happened when he went to the service 2 times
08.05.2020 18:39 # 11
yigit
As I said, he was a master in the industry I took away, he removed the fuses, he got better. but he warned me brother said repeat problem. said the fuse box is problematic. Ask him again as he said later. When I took out the fuses myself, the car locked itself. so i couldn't get it running. My aim was to go to the peugeot service because the car never worked. Thanks a friend there helped a small cable from the battery to the vehicle brain (took a chassis) car worked. I told them the problem of high beams there. He said that in the service, as my master said, the fuse box should change. It cost around 700 TL. I didn't get it. After that day, I had a headlight problem 1 or 2 times in 3-4 months. As I said, the problem disappears with a few clicks on the fuse box under the bonnet. But I have noticed that this is usually a problem when I wash the car or in rainy weather. may be getting water from somewhere
08.05.2020 18:39 # 12
pusutr
I think you should check the wicks of the hood. Of course, the possibility of incontinence happens if it is old.
08.05.2020 18:39 # 13
yigit
yes there is some wear. i think i will change it as soon as possible
08.05.2020 18:39 # 14
okaNStarss
I don't have water, but I suspect the arm, but why the fuse box fails
08.05.2020 18:39 # 15
yigit
I don't think there will be a problem if there is a clicking sound when he turns the handle and take a look at the instrument panel. If everything is normal, as I said, it is from the fuse box. if you want to look at an electrician. I hope it is not a fuse box. maybe it is dusty or as I said, there may be cable contact etc.
08.05.2020 18:39 # 16
okaNStarss
I'll be the authorized service to disassemble and install everywhere of this vehicle.
08.05.2020 18:39 # 17
yigit
That's where you first look: D open the fuse box cover under the hood, grab a hammer in your hand. knock lightly against the fuses. But while doing this, do it while the longs are burning. So try it when your vehicle has trouble. it is useless to do it when you're strong :)
08.05.2020 18:40 # 18
TaZ
I have written a long article about the headlights being hungry in the past, it is very likely that when you go to the electrician, it will not be repaired when you go to the electrician. It is very simple in its solution, but the skill will need to disassemble the brain completely, remove all the fuses, place the headlamp roles there, sold out the cable and fix it with a role from the estra.
08.05.2020 18:40 # 19
yigit
exactly. I mentioned above 2-3 days ago. most likely from insurance
08.05.2020 18:40 # 20
okaNStarss
let's see when i do it again i have not tried since then :)
Page : / 2
