High beam for winter
21.07.2020 14:52 # 1
Adali34
I am a masters 307 user, I tried to auto adjust the headlights, when the ignition is on, the lights go off when the switch is turned off. Doesn't it normally need to burn less during the day and stronger at night. It lights up with the same feature day and night. In addition, the vehicles in front are disturbed by the headlights at night, the short ones are burning but they think I am lighting long :))
21.07.2020 16:16 # 2
Orcun.Dmr
Headlights do not light up at all during the day in "AUTO" mode. There is probably a problem with the gel of the headlight and rain sensor. The issue of eye-catching is related to the headlight settings, when the headlights are adjusted with the adjustment machine, your problem will go away.
22.07.2020 14:42 # 3
Adali34
Thank you very much, master. Well, you can get this gel setting done by Nerd. Headlight adjustment
22.07.2020 21:01 # 4
Adali34
I wonder if there is xenon because it burns so much
