Hi
08.05.2020 13:58 # 1
My problem is my master, nowadays, the car is warming up and stopping later than the previous one 10-15 minutes after starting the other day, it stopped when the engine was at a reasonable temperature, I did not use the vehicle for 2 months. or why?
08.05.2020 13:58 # 2
We will help if you give more information about the vehicle ...
08.05.2020 13:58 # 3
of course my car is 2001 model 206 gti 105 thousand km
The throttle was cleaned and the engine was washed 2 weeks ago in the service.
08.05.2020 13:58 # 4
I do not think it is related to not using it for a long time, but the throttle and the idle valve (step-by-step engine) operation should be done, I think I think it might have made a very important malfunction and have a look at the spark plugs ...
08.05.2020 13:58 # 5
There was no such thing before disassembling the throttle. As far as I can understand, can you take care of these Maintenance-Repairs at a convenient time?
08.05.2020 13:58 # 6
Let me add a bidet, my master seems to me that my car does not accelerate as well as before, so there is no problem at the top speed, but it is a bit like contraction in low gear
08.05.2020 13:58 # 7
sinan-s
Get a carbon clean ..
08.05.2020 13:58 # 8
the difference in pt is immediately given information :)
emrah 2008-11-15 12:52:42
08.05.2020 13:58 # 9
[QUOTE = gs5165] My problem is, my problem is that the car is warming up later and stopping later than it used to be. 10-15 minutes after starting the other day, it stopped when the engine was at a reasonable temperature and I did not use it for 2 months. or why? [/ QUOTE]
It is at a lower temperature than later heating.
If the engine has stopped, the Coils and Gas Pump are the first possibilities I can think of.
08.05.2020 13:58 # 10
Thanks for your interest
08.05.2020 13:58 # 11
barisaso
I cleaned the butterfly, the tachometer did not improve again, normally it should stop at 9, while it turns to 10 a
08.05.2020 13:58 # 12
that means the butterfly should not be cleaned :)) I have the same problem with me
08.05.2020 13:58 # 13
Late heating of the vehicle is due to cold weather conditions ... But there are many reasons why the engine stops to a stop ... It is useful to show your vehicle to the place where you are maintaining for the final diagnosis.
