Here's my steering gear missing oil from here
08.05.2020 16:06 # 1
Burak07
My steering wheel steals oil from this metal pipe, and in my case, should it be completely changed, or is there any other solution? it usually starts to miss more when I turn it to the right. src = "http://img10.imageshack.us/img10/9440/2003cj.jpg" border = "0" />
Burak07 2011-09-12 20:10:26
08.05.2020 16:06 # 2
If it is missing from the joint of the record, it may be easier to repair it. If there is a problem in the drain pipe, I think it will be more costly ...
& nbsp;
Get well soon
08.05.2020 16:06 # 3
Burak07
cem bro is kidnapping the pipe from there, as if they didn't tighten it with a bolt, but I can not say anything of course.
08.05.2020 16:06 # 4
Eleanor_
turning the steering wheel right and left to the left, you should not hit the bottom, causing the blowers to burst.
08.05.2020 16:06 # 5
Burak07
How does it hit the bottom? So the 106's steering pumps do not come to the full tour, so the cart is on fire, so I do not turn a full turn :(
08.05.2020 16:06 # 6
Eleanor_
How do I explain when you park right or left or right when it stops, it hits the bottom when the steering wheel comes to an end or you shouldn't do it.
08.05.2020 16:06 # 7
Burak07
or even when I do not make a full bottom, it flows even when I turn it normally so there is no escape .. & nbsp;
08.05.2020 16:06 # 8
Eleanor_
Now the bellows is tearing where it stops because it is torn, so when you make the car I mean, you should pay attention to it: )
08.05.2020 16:06 # 9
Burak07
the bellows is already cheap 20 pounds, I guess it is in sahinpeugeot :) but we need to show it to a good master and get his approval there is not a good master here.
08.05.2020 16:06 # 10
serdar026
Man, the same problem happened in me, the master was able to detect the place that was kidnapped and clenched after him. I did not have any problem after that. serdar026 2011-09-12 22:10:08
08.05.2020 16:06 # 11
Burak07
[QUOTE = serdar026] Dude, the same problem happened with me, the master was able to detect the place that was kidnapped and clenched, and then I had no problem. [/ QUOTE]
I'm afraid of him too, if he squeezes his salmon or something, it will be licking "C Reviews
