Helpers with information about Watt in the speaker
08.05.2020 18:17 # 1
herry
Guys, I think my rear speakers burst recently, I can see that the bar burst in pieces. I have to change it, its size is 10cm. I'm going to connect a new one myself, but for those who know I will have a question, I will order online. My confirmation in my vehicle is necvox brand and it has 4x45w output, I have an anf, but the bass amplifier only feeds the subwoffer, so my rear speakers are fed from the tape. I am looking at 10 cm models. .. I don't know much about what these are. Can you help me.
I will buy from the address, you can recommend a model here, I need the help of friends who have knowledge.
http://www.hepsiburada.com/liste/department.aspx?q=fh_location%3d%2f 2fcatalog01% of 2ftr_t% 2f240_dp%% 3d {hoparlf6 they} 2f111_dp%% 3d {1020cm} 2fcategories%% 3C {catalog01_60002705} 2fcategories%% 3C {catalog01_60002705_2147483631} 2fcategories%% 3C {catalog01_60002705_2147483631_253575} 2fcategories%% 3C {catalog01_60002705_2147483631_253575_26090} 26fh_refpath%% 3dauto_generated_facet_73800 26fh_reffacet 3d111_dp%%%%% 26fh_refview is 3dlist 26fh_view_siz to 26catego% 3d12% ryid 3d26090 26sc%%% 3d32 & amp; sc = 8 Reviews
08.05.2020 18:17 # 2
barishrocker
you can get it from there. & nbsp;
I listen to them We would take my brother in the car in time. they play very well ..
http://www.n11.com/hertz-dcx-100-10-cm-coaxial-hoporlor-7227-P10783591
& nbsp; here is more affordable .. http://www.sanalpazar.com/Hertz-Dcx-100-Koaxial-Hoparlorler__isp4250531 < / a>
08.05.2020 18:17 # 3
herry
thank you I will evaluate, according to what he says the way? and does the high wattage trouble?
08.05.2020 18:17 # 4
ferhattasdemir
I just bought the 13cm ones of sony and I can say that the sound is not good at all. There is no amplifier in my car, maybe I don't know it. But I can say that I could not get the sound I expected from Sony. & Nbsp;
08.05.2020 18:17 # 5
barishrocker
If you take very high watts, the sound will not sound nice because there is no amp. it is useful to buy the lowest wattage .. normally 3way is better than 2way, but if you do not feed with enough power, do not get stuck because the quality will decrease. If you are going to feed with tape outlet, take the low wattage. friend used jbl 10cm, he said good. I looked at the price as well now ..
08.05.2020 18:17 # 6
rizeli_53
wat also doesn't matter, RMS is important for your speaker.
08.05.2020 18:17 # 7
herry
i would appreciate if you inform ali rms a little bit, it doesn't write rms in the ads for example
08.05.2020 18:17 # 8
yawruaslan
according to the values that I know peak and rms on the speaker I know p eak can exit instantly with < span style = "font-size: 13px; line-height: normal;: rgb220, 220, 220;"> is strong. It will cause damage if it is continuous. RMS shows the power it can give continuously. In my opinion, I will get 1000w peak 250w rms, I will get 1000w peak 400w rms for a good lecture with a high rms value, I will get 1000w peak 400w rms :) If I am, I will put the installation on the front doors soon, I will also buy hertz at the front doors. i think my tape has sony mono amp, beautiful bitane behind myth pioneer legend pioneer 6985 have bidet stereo amplifier, hertz mids and 6985s stereo amphitheater, 30cm hertz bass in the trunk, and I connect it to mono amphitheater, it will be okay, but hertzi is only good quality
08.05.2020 18:17 # 9
herry
[QUOTE = yawruaslan] according to the values that write peaks and rms on my speaker p eak can appear instantly with is strong. It will cause damage if it is continuous. RMS shows the power it can give continuously. In my opinion, I will get 1000w peak 250w rms, I will get 1000w peak 400w rms for a good lecture with a high rms value, I will get 1000w peak 400w rms :) If I am, I will put the installation on the front doors of the car soon, I will also buy hertz at the front doors. i think my tape has sony mono amp, beautiful bite behind myth pioneer legend pioneer 6985 there is a bite stereo amplifier, hertz mids and 6985s stereo amphitheater, 30cm hertz bass in the trunk, and I connect it to mono amphitheater, it will be okay, but hertzi is only good quality [/ QUOTE]
Thank you for your sharing but I do not think of getting a new amplifier. Because when I first got the car, my system in the trunk was measured and assembled according to the convertible system, I don't want to touch it. I will replace the existing ones with a new one. By the way, your system is very good "Thumbs offspring discotheque Reviews
08.05.2020 18:17 # 10
Brk44
Rms stuttering these were mid teams and valid on devices such as bass;) You should use 2 ways if you feed directly from the tape.
08.05.2020 18:17 # 11
herry
[QUOTE = Brk44] Rms stuttering were mid tools and valid on devices like bass;) You should use 2-way directly from the tape, be careful not to have a 10cm hertz, jbl, kcker, focal, cadance but amp if you don't feed with amp. & Nbsp; [/ QUOTE]
Which sister of Burak do you suggest?
http://www.hepsiburada.com/liste/ sony-speakers / department.aspx? q = fh_locatio the% 3d% 2f% 2fcatalog01 is 2ftr_t% are 7bhoparlf6 3d% 2f240_dp%%% 7d% 2f111_dp% 3d 7b1020cm%% 7d% 2fcategories% 3c% 7bcatalog01_60002705% 7d% 2fcategories% 3c% 7bcatalog01_60002705_2147483631% 7d% 2fcategories% 3c% 7bcatalog01_60002705_2147483631_253575% 7d% 2fcategories% 3c% 7bcatalog01_60002705_2147483631_253575_26090% 7d% 2fbrand% 3d 7bsony% of 3bpione% 3bjbl%% 7d% 26fh_reffacet 3dbrand% of 3dlist% 26fh_refview% 3d12% to 26fh_view_siz%% 26fh_refpath% 3dfacet_4% 26fh_sort_by% 3D- 2c 252bmin_actual_price_pl%%%% 3d26090 order_stock_attribute_pl 26categoryid 26sc% 3d8% Reviews
08.05.2020 18:17 # 12
barishrocker
No need to buy a pioneer as the car has a subwoofer. Pioneers are more bass player. If you say hertz dcx 100 is expensive, sony or jbl is good.
08.05.2020 18:17 # 13
herry
[QUOTE = barishrocker] No need to buy a pioneer as the car has a subwoofer. Pioneers are more bass player. If you say hertz dcx 100 is expensive, sony or jbl is good. thank you :)
