Help with the victim of porcho please |
| 08.05.2020 20:07 | # 1 |
| 08.05.2020 20:07 | # 2 |
Rust on pipes etc. Since the water is recirculating since it comes to light, the appearance of rusty water is more effective if you pour boiling water first instead of normal pressure water ...
| 08.05.2020 20:07 | # 3 |
Halil5759 |
After draining the system liquid completely, rinsing it with water several times, fill it in half with antifreeze water and follow for a few days.
| 08.05.2020 20:07 | # 4 |
If you touch the boiling au as you said, touch the water inside and put a new one, do you think the same situation will happen to me?
| 08.05.2020 20:07 | # 5 |
It is said that the rock salt neutralizes the acid, would it be useful if I get your help
| 08.05.2020 20:07 | # 6 |
dejawu1978 |
I think that you change the water in 1-2 days with a small amount of antifreeze supplement.
| 08.05.2020 20:07 | # 7 |
[QUOTE = dejawu1978] I think that you should replace the water in 1-2 days with a small amount of antifreeze supplement. [/ QUOTE] In fact, while I was cleaning, I touched all the water and took out the hose of the heater honey and just gave it there. I don't know what the honeycomb sucked. |
| 08.05.2020 20:07 | # 8 |
sonerkyl |
My teacher, take the best pure water, drain the water in the radiator, use the tool until you open the thermostat, then pour the water again when the engine is robbed, make a mixture of pure water and anti-freeze.
| 08.05.2020 20:07 | # 9 |
In the meantime, you can get pure water from home air conditioners :) I would like to present it as extra information. As long as it works from the air conditioner in summer or winter, water drips are used in 1 carboy radiator water per week.
| 08.05.2020 20:07 | # 10 |
I will implement what you say this Sunday, teacher, let's share what will happen.
| 08.05.2020 20:07 | # 11 |
KILIC |
[QUOTE = mehmet_2792] I will apply what you say this Sunday, teacher, let's share what will happen. [/ QUOTE] In my opinion, change your water a lot and then put an antifreeze.
