Help with the malfunction lamp ...
08.05.2020 15:02 # 1
dante0668
good evening everyone..
I noticed today, when I opened the ignition of my vehicle, the hand brake, the battery and a yellow icon similar to the engine block on the upper left cross of the hand brake are flashing 2-3 seconds after starting the car.
thanks ... car peugeot 206 hdi
dante0668 2011-01-17 00:24:38
08.05.2020 15:02 # 2
sercinho
If he was behind a normal heral vehicle, a sign like a slick on the slippery ground, I went to see a vehicle bskmsays, it was burning in me, I don't have anything in the guide.
08.05.2020 15:02 # 3
dante0668
there will be a rough sketch but it would look like this figure =)
http://img135.imageshack.us/i/buekilde.png/
At 12 o'clock in the evening, I thought: D
I think it was burning before, it caught my attention today
dante0668 2011-01-17 00:42:45
08.05.2020 15:02 # 4
sercinho
If the normal engine malfunction lamp turns on after running it, no problem. If it comes on while moving, there is a problem. Don't worry.
08.05.2020 15:02 # 5
dante0668
If it flashes suddenly while working, there is a problem, but this is okay, right?
08.05.2020 15:02 # 6
sercinho
OK, no problem, you live in Ankara. If you think I am in Ankara, you will be a new member. If the engine fails, the soner lights up continuously.
08.05.2020 15:02 # 7
dante0668
thanks a lot .....: D
08.05.2020 15:02 # 8
sercinho
You're welcome, good night.
08.05.2020 15:02 # 9
sistemci
I have 307, no wrong information but; I think all of those he counted are present in every vehicle.
08.05.2020 15:02 # 10
metin
[QUOTE = sercinho] If that normal heral vehicle was on the slippery ground, I had a bite like it was on the back today, I went to a vehicle bskmss, it was burning in it, I don't have any information about this sign in the guide, but if I think there is no information about it, I did not know anything about this issue yet.
it is abs light. if you notice that there is light but no abs light (: it is abs light as I said.
quiet_20 2011-01-17 09:03:50
08.05.2020 15:02 # 11
sercinho
yes, in the old models of 2002, the abs is burning in the new ones.
08.05.2020 15:02 # 12
hhuzun
it is normal that the light ends after 2 3 seconds
Because the oil in the motor goes into operation, soner
but if it burns long, it means there is a problem
08.05.2020 15:02 # 13
The lamp you are talking about is the engine fault diagnosis lamp. some have a complete engine signal. If there is no malfunction after starting the engine, it should end after 2-3 seconds. It has nothing to do with motor oil. The oil lamp is already separate. is a sign of oil ...
The abs lamp is like a slippery road sign on old vehicles, and on the new one it writes abs ...
08.05.2020 15:02 # 14
komando
Mine burned in the course, even wrote on the yo computer apollotion foult I pulled the car aside and stopped it after 1 minute and started it again and then it burned again. rejoice 307 xt 2.0 hdi 2002
08.05.2020 15:02 # 15
sercinho
my friend beny is changing, which one do you go to service, i have a problem in your car, i have a problem with airbreak
08.05.2020 15:02 # 16
a normal situation does not need to panic.
08.05.2020 15:02 # 17
komando
Walla has changed the air filter, but some say it is from the catalyst.
08.05.2020 15:02 # 18
Eyup Duygun
If the malfunction lamp is on, it means that there is a certain problem. If the wipe with the Planet2000 device is burned and burns again, there is no doubt. Be careful not to get out of the vehicle, but the service is already broken.
