help with sound from left front wheel
08.05.2020 18:35 # 1
cansytnn
I get a sound that everyone can hear as my car passes through the pits 307 , even when passing over the smallest sewer door, a strange sound comes from the left front of my car.
Let me define the sound as follows: I give an example sounds like a sound when the 10 bracelets hit each other on the arm sounds like a ring sound. How can I solve this problem? does anyone knows
08.05.2020 18:35 # 2
samet206
I guess this may be the space you can make from the rods of the arms, this is what causes your problem. Other front team failures are as follows.
08.05.2020 18:35 # 3
cansytnn
it doesn't make a sound when I turn the steering wheel, but there are two other problems, of course
08.05.2020 18:35 # 4
Helentemoller
I had the same voice. As if the chain is rubbing on the ground or the key is swinging. There was a sheet protecting the rods of the rods, he played from that place, they fixed it. The sound is gone.
08.05.2020 18:35 # 5
cansytnn
So if I take it to my service, it may not even charge? I think they shouldn't take it, they wouldn't take something to fix it.
08.05.2020 18:35 # 6
Helentemoller
they didn't take it from me, though they may not have bought a service that my father always went to
08.05.2020 18:35 # 7
MasMavi
I had the voice you mentioned. coming from the left front wheel. I had read in the forum before. There is a small piece of sheet metal that protects the rod ends. I pulled the car down so I could get under it. I noticed that the sheet metal piece was loose. I put it in place and tighten it from the clips with pliers. the voice was stopped. you can do it yourself.
08.05.2020 18:35 # 8
okaNStarss
or hitting the tray at the bottom of the augers, you can pass the plastic water pipe to the hezones. okanstarss 2014-08-01 22:19:25
08.05.2020 18:35 # 9
206x-line
tie rod is not the same, there is a protection shield like a sheet to protect the disc.
08.05.2020 18:35 # 10
rzsrht
[QUOTE = MasMavi] You had the voice you mentioned. coming from the left front wheel. I had read in the forum before. There is a small piece of sheet metal that protects the rod ends. I pulled the car down so I could get under it. I noticed that the sheet metal piece was loose. I put it in place and tighten it from the clips with pliers. the voice was stopped. you can do it yourself. [/ QUOTE]
brother, do you have a chance to upload a photo? If I see the exact material, I try to make it .. I have the same voice. I'm getting scabies.
08.05.2020 18:35 # 11
Ali1905
just like Photo, I sometimes hear that sound, maybe it helps
08.05.2020 18:35 # 12
ercn86
[QUOTE = samet206] I guess there might be space from the rod arms that I guess is what causes your problem. The other front team malfunctions are as follows: If the shock absorber blows out, it makes a creak-like sound, it makes a creak-like sound about the swings every time you turn the steering wheel.
When I turn the steering wheel left and right in my vehicle, it seems as if the hose is rubbing. Could there be a problem in the swings due to the hose that goes under this spring? What else causes the swing failure?
08.05.2020 18:35 # 13
MasMavi
[QUOTE = rzsrht]
I did not have the opportunity to take a picture of my brother, but I found a picture of the same piece. Part 2 faces the brake discs. you put the part back in place and tighten it from the opposite "B" clips. I hope it works for you.
Azure 2014-08-03 02:47:13
