help with rim selection
08.05.2020 16:32 # 1
simirnoffredbull
My vehicle is 1.4 petrol 307. I have 17 inch wheels on my vehicle and 205/50/17 tires ... I want to make a 15 or 16 inch steel wheel on the rim to save fuel. I wonder which wheel should I choose and which tire should I use on the rim I choose ... if you help me with this, I will follow a path accordingly .. Thanks for your valuable thoughts in advance ..
08.05.2020 16:32 # 2
06OzGuR06
My advice would be to return to the original rim and tire sizes for 307. If you return to the original tire sizes 195/65/15, these will reduce fuel consumption. I recommend you michelin energy saver as a tire in these sizes.
Check out the tire here, but do not buy the tire from the dealer, because the production date of the tires is very important and prefer the tires produced in the last 6 months. < br>
http://www.lastik24.com/Urun/michelin-195-65-r15-91h-energy-saver-grnx-_98
For rim review purposes
http://www.lastik24.com/Urun/6-5x15-4x108-et25-replica-301-pejo-jant_86
06ÖzGüR06 2012-01-24 01 : 34: 24
08.05.2020 16:32 # 3
djchaos
There is not much difference between 17, nç and 16, but if you say both fuel and performance, 15 inch light alloy wheels have 18 inch wheels in my car when I say performance, 225 40 rims make it a bit more bulky on departure but it does not beat the long road :)) increases fuel. an extra load on the vehicle
08.05.2020 16:32 # 4
simirnoffredbull
I am thinking of returning to 15 inches, frankly, my car trembles on departures, it can not lift it, it can not lift it. Thanks for your thoughts.
08.05.2020 16:32 # 5
ibrahim YILDIZAK
[QUOTE = simirnoffredbull] I am thinking of turning to 15 inches, frankly, my car trembles on departures, it can not lift it, 17 thanks..thanks for your thoughts [/ QUOTE]
The dashes at the departure may be caused by the pressure starter.
08.05.2020 16:32 # 6
06OzGuR06
[QUOTE = ibrahim YILDIZAK] [QUOTE = simirnoffredbull] I am thinking of turning to 15 inches, frankly, my car trembles on departures, I can not lift it 1717..thanks for your thoughts. > [/ QUOTE]
Yes, the shaking of the departures is related to the press brake.
08.05.2020 16:32 # 7
ibrahim YILDIZAK
[QUOTE = 06ÖZGÜR06] My advice would be to return to the original rim and tire sizes for 307. If you return to the original tire sizes 195/65/15 for your vehicle, the fuel consumption will decrease. I recommend you michelin energy saver as a tire in these sizes.
Why are the prices here so cheap?
08.05.2020 16:32 # 8
[QUOTE = ibrahim YILDIZAK] [QUOTE = 06ÖZGüR06] My advice would be to return to the original rim and tire sizes for 307. If you return to the original tire sizes 195/65/15 for these sizes, the fuel consumption will decrease. I recommend you michelin energy saver as a tire in these sizes.
normal prices I think .. how much did you guess? & Nbsp;
08.05.2020 16:32 # 9
06OzGuR06
Prices are very close to the dealer prices "Smile"
08.05.2020 16:32 # 10
Gkn61
I Have 307 1.4 I Have 16`` I Want To Install Wheels I Don't Afraid To Remove The Car. You Are 17`` Are You Halal :) :)
