help with oil !! (Thanks to SOLVED FORUM)
08.05.2020 16:58 # 1
GiTaRRa
my friends have bought 10.40 castrol magnetec oil to my vehicle and completed it was a bit missing. oil is thinned and burned, I think it was added ... 2 liters were touched in the evening, added 20.50 pump pump bpet oil in the summer of 20.50, you need to use 10.40 in the summer. .. GiTaRRa 2012-08-11 00:00:47
08.05.2020 16:58 # 2
hsnsnl
my thought is that if we change the oil of the vehicles & nbsp; summer fat, it will be wrong .. it will be wrong if the oil is 10.40w. It is useful to change it .. if you think that the vehicle .. it may be possible from the coolant event.
08.05.2020 16:58 # 3
It would be better if the oils did not mix.
08.05.2020 16:58 # 4
Serkan
I think different viscosity oils should not be mixed. it should not even be used in 20/50 passenger vehicles.
08.05.2020 16:58 # 5
berk2309
10x40 will not be 20x50, my teacher & nbsp; oils do different damage to the vehicle, as the friends say the same oil is used 10x40 & nbsp; summer is used the same oil, its used commercial vehicles are cheap, they use a few different oils in summer & nbsp;
08.05.2020 16:58 # 6
I recommend that you drain the oil completely and add new oil. You will also replace the filter.
08.05.2020 16:58 # 7
sahin-peugeot
do not put 20w50 oil 106 or do not do unconscious work pity, I think you can immediately empty the network and say 10w40 total or mobile sheep
08.05.2020 16:58 # 8
[QUOTE = sahin-peugeot] never put 20w50 oil 106 or do not do unconscious work pity, I think you can immediately empty the network and put 10w40 total or mobile sheep [/ QUOTE]
I'm done there
" pump pump bpet oil in the summer of 20.50 you should use 10.40 "
08.05.2020 16:58 # 9
Serkan
My advice is not even 10/40, if you trust your vehicle, if you say that oil will not decrease, I definitely recommend 5/40 full synthetic oil, I have been using castrol edge 5w40 full synthetic for the last two maintenance. Whether the car sound or performance has changed dramatically.
08.05.2020 16:58 # 10
sahin-peugeot
TU3JP will be more suitable for the engine 10w40, diesel engine 5w40 5w30 can be used, but since the new generation engine is used, it can be put 10w40 on the old 1.4 gasoline engine, let the pump do its own work and do not mix with the oil :)
08.05.2020 16:58 # 11
istanbullu_3886
I think, my friend, the oil incident is very important for the engine. If we need to give blood like the blood circulating in the veins of the same person, there is a blood group in the human or if we give the blood of a sheep, there is a thickness between 20-50 and 10-40. It has been made according to the oil if the oil is thick enough not to pass through the ducts, the engine will die fast since the engine cannot lubricate adequately & nbsp; you can even wrap a bed in my mind and change it to the oil recommended by the manufacturer.
08.05.2020 16:58 # 12
GiTaRRa
friends are set at 20.50 but I am going to change the oil in the morning considering the suggestions of my friends in the forum. said to go to the pejos total said the service was said to be a french brand in total Thank you for your interest and comments ...
08.05.2020 16:58 # 13
you are doing the best. There is also a total expense for pejos. It may be the factory standard but there are also brands of higher quality oil than tota.
08.05.2020 16:58 # 14
berk2309
so the one that suits the engine is 10 40, but you can use what brand you want
08.05.2020 16:58 # 15
GiTaRRa
total 10.40 was used. When the oil in it mixed with grease, my hoarse running motor found a new life with bormax and totatl ...
08.05.2020 16:58 # 16
muratoner
Let's look at your eyes.
