help with gasoline needle please
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:18 # 1
gngburak
Everyone has a good breakdown
4-5 months ago, the gas pump had failed. I bought gasoline in 20tl, the needle has not moved anyway. Can I do it if I get up is risky.
08.05.2020 17:18 # 2
Serkan
Don't rush, I think if you don't move in the next gasoline, then you will look for a solution
08.05.2020 17:18 # 3
hsnsnl
You need to pass 7 liters and 7 liters.
08.05.2020 17:18 # 4
Serkan
Hasan Hasan who has already received 50 TL
08.05.2020 17:18 # 5
hsnsnl
sorry sorry :) If he put the car down somewhere, friend, your gas will come to the front of the vehicle.
08.05.2020 17:18 # 6
werty
20 tl does not detect the receipt of gasoline & nbsp; does not play the needle 30 tl and + moves to the medicine. If possible, throw off 50 more petrol and then act according to the result.
08.05.2020 17:18 # 7
carantinas
Make sure there is a problem with the float because if I buy the car for 20 lira, the pointer is playing. or when I turn off the ignition and open the next day, the needle comes to the spontaneous sphere or wait for a while or if there is no movement, the samandra dandir is 400 lira original pump by the way.
08.05.2020 17:18 # 8
plawert
I think it would be better to try and fill the tank of the vehicle after the newly installed pump.
08.05.2020 17:18 # 9
cey cey
Take it to the master, take it to the master, take it to the master, show him what he will say, after all, you gave money, maybe there is a process that is complete or defective.
