Help with daytime running light
08.05.2020 18:22 # 1
pekmez006
Friends, today I will ask about the very common daytime running lights; The malfunction lamp will light. How do we assemble it? Is there a legal problem. I would like to thank you for your help, the installation of which is of great importance. Serkan 2014-03-13 20:13:34
08.05.2020 18:22 # 2
tetik-soner
malfunction does not light
easy to assemble to park the cables
If you are going to buy money, buy something well or it won't last long
no punishment
08.05.2020 18:22 # 3
pekmez006
Hodja, can't we do key mounting externally and how do we connect to parks?
08.05.2020 18:22 # 4
I think there is no need for that kind of work merco / bmw work,
08.05.2020 18:22 # 5
Serkan
I think there is a lot of safety in the non-original vehicles. Serkan 2014-03-13 20:14:13
08.05.2020 18:22 # 6
pekmez006
It is wrong to differentiate this modified heat from pleasure because it is original.
08.05.2020 18:22 # 7
Serkan
[QUOTE = pekmez006] It is wrong to distinguish this modified heat as the pleasure pleasure is original [/ QUOTE]
You are right, I have already stated my opinion as `` I think ''.
08.05.2020 18:22 # 8
KIZILASLAN
I thought about it, but I gave up, it looks like a flashing sanroof in the car
08.05.2020 18:22 # 9
pekmez006
If you hold it and wear a big thing, it will be glamorous but it gives a stylish appearance with a polite and beautiful assembly.
08.05.2020 18:22 # 10
pekmez006
The light intensity of the leds diminishes when the headlights are turned on. Well known parks are good at night, their headlights can be a problem at night pekmez006 2014-03-13 22:48:17
08.05.2020 18:22 # 11
pekmez006
Well, I want to plug in an external key. Is it difficult? pekmez006 2014-03-13 23:56:13
08.05.2020 18:22 # 12
pekmez006
They'd better think they'd think the fog light and write a penalty :-) Brother how I connect to the parks I want from you is detailed, but brother :-)
08.05.2020 18:22 # 13
ERDINC
Connecting the led with parallel cable line is a very easy process. Everywhere in my vehicle is led, yellow wires - the pole is important, in finding the park +, open the parks, disconnect the headlight socket and touch the end of the led in your socket. tie it up, we want to see the pictures when you make bukadaaaar
08.05.2020 18:22 # 14
pekmez006
[QUOTE = ERDINÇ] Connecting the led with parallel cable line is a very easy process, everywhere in my vehicle is led, yellow wires - pole is important in finding the park + which is important, unplug the headlight socket and it is worth the end of the led + light in the socket when it finds the end where the led is lit. peel and tie the end of the cable and we want to see the pictures when we make bukadaaaar [/ QUOTE] thank you very much now I understand now there is no need to wear a fuse or so pekmez006 2014-03-14 03:21:27
08.05.2020 18:22 # 15
206+bulent
There are remote controlled ones whenever you want.
08.05.2020 18:22 # 16
Alicilik
Little patience. I am taking lessons from Cenker brother about the working principle. No need to hit the button
08.05.2020 18:22 # 17
pekmez006
[QUOTE = Receiving] Little patience. I am taking lessons from Cenker brother about the working principle. No need to hit the button [/ QUOTE] I want Ali to stop his headlights as soon as possible. Just how should I do something?
08.05.2020 18:22 # 18
Alicilik
When my headlights turn on, 20% of the track ends.
I just need to make him a module.
08.05.2020 18:22 # 19
ERDINC
connect the plus of the leds to the parks, plus the dipped headlights to the parks.
08.05.2020 18:22 # 20
pekmez006
[QUOTE = ERDİNÇ] Connect the plus of the leds to the parks and the downside of the dipped headlights. When the lights turn on, the leds turn off. I applied it.
Page : / 2
