Help with 307 heat indicator
08.05.2020 14:09 # 1
ozgurkso
Hello friends, I traveled 500 km with my 307 1.6 hdi vehicle when the weather was around 0 degrees. The temperature did not exceed 75 degrees. Even when the gas cut off in a snowy part, the indicator went down to 50 degrees. Is this normal? I request
08.05.2020 14:09 # 2
Onur
I do not think there is a problem, it does not exceed 75, especially on the long road, the vehicle is constantly receiving wind from the front, but you say it went down to 50. I do not think it will be a problem.
08.05.2020 14:09 # 3
ozgurkso
Thank you, if you say the situation is the same in other 307 people, it's okay.
08.05.2020 14:09 # 4
Onur
[QUOTE = ozgurkso] Thank you in the other 307 hdi, if you say the same is ok.
08.05.2020 14:09 # 5
don't bother normal
08.05.2020 14:09 # 6
ozgurkso
[QUOTE = polatkaptan] normal boring [/ QUOTE]
For the first time, I use a peugeot, but it may be normal. I have used many different vehicles so far, the cooling system kept the temperature in the ideal temperature range.
08.05.2020 14:09 # 7
H-a-d-i
performance can drop noticeably, consumption also increases. but I think it is better than the cost it will incur due to the heat.
I also think it's normal.
h_307 2010-01-28 00:11:00
08.05.2020 14:09 # 8
yigit1989
I don't always know 80 degrees
