Help with 307 child lock problem
08.05.2020 18:33 # 1
rzsrht
Friends, you know that there is a child lock on the left rear door of the vehicle. Normally, the door is made active and passive from the red ground. But mine is not working no matter what side you turn.
Edit: child lock is now active. The door does not open from the inside. Every time I get out of the car to open the door of the backseat.
Is there a solution for this I can do? Or does he really want a master? rzsrht 2014-05-15 13:02:52
08.05.2020 18:33 # 2
hakan574
turn it on then try to open the door from inside while the driver's door is open but it was okay later.
08.05.2020 18:33 # 3
Serkan
The child lock works in the same way for me, and I constantly open and open the door of those sitting in the arkads.
08.05.2020 18:33 # 4
Istanbullu 307
Hello friends
I didn't know it was child locked. How is it made active and passive?
08.05.2020 18:33 # 5
KILIC
[QUOTE = Istanbul from 307] Hello friends
When the back doors open, there is a plastic that looks like a red screw on the side of the door.
SWORD 2014-05-15 13:41:53
08.05.2020 18:33 # 6
rzsrht
Hello friends
My brother AC on the left back door. There is a red place in the lock section of the door. A key like the airbag active passive place in the central console. You activate it. So
08.05.2020 18:33 # 7
rzsrht
[QUOTE = hakan574] turn it on then try to open the door from the inside when the driver's door is open but it was okay but it was okay later.
I will try and give information, thanks.
08.05.2020 18:33 # 8
Istanbullu 307
Thank you
08.05.2020 18:33 # 9
Istanbullu 307
Hello friends
I activated the child lock. I opened the child lock when the driver's door was open or closed. The rear left door has not been opened from the inside, it must be opened from the outside. No solution?
Thanks
08.05.2020 18:33 # 10
Istanbullu 307
Thanks, child lock is working. But this time, I have to open the back left door every time.
When the driver opens his door, the back left should be able to open from the inside, normally.
Thanks
08.05.2020 18:33 # 11
Istanbullu 307
Hello friends, I need a 4-way glass control (with electronic components inside etc.) on the driver's side for pejo 307. Do you have any dating?
