Help with 306xr lpg
08.05.2020 18:35 # 1
bahadir52
Hello friends.
I have a 1998 model 18.xr automatic peugeot, I am the first owner of the vehicle.I did not get lpg until this day, but I had to install it because it burned so much, the people I talked to said that the atiker seafast was fitting. it keeps getting strange when you stop I don't know what to do please help
08.05.2020 18:35 # 2
ErdiCoskun
Man, get past, I'm an enemy of LPG, openly, if you give 3000TL and get prins, you will definitely have a problem after a while. But of course, we can not say that there is a problem in the lpg, but maybe there was a problem before the lpg, but it did not cause any problem in the gasoline. Of course, it may also be related to the lpg settings, the throat butterfly may be dirty, it may be related to the ignition system. the erdicosk 2014-06-01 11:41:05
08.05.2020 18:35 # 3
bahadir52
Thank you, I would like to use it in gasoline, as I know, I endured for 5 TL 16 years but it does not.
08.05.2020 18:35 # 4
Serkan
There is a problem with your potential settings, they should review the settings.
08.05.2020 18:35 # 5
pierson
I have a 206 xr vehicle..auto gear..atics LPG is installed.There is a ticking sound when the car is switching to LPG or that sound is often frequent ... that is, it changes to the gas and then the sound comes to the back again, and the green light is flashing. I wonder ...
08.05.2020 18:35 # 6
bahadir52
click sound I hear a lot of vehicles.
08.05.2020 18:35 # 7
Serkan
[QUOTE = pierson] I have 206 xr vehicle..automatic gear..atiker LPG is plugged in. When the car is switching to LPG, there is a ticking sound, or that sound is frequent sometimes. I wonder why this may be .. the master also did not understand .. [/ QUOTE]
The sound of the sound role you mentioned is heard only once when the sound is switching from lpg to gasoline, if there is a continuous sound, it means that the vehicle is constantly switching gas-gasoline, I connected it to the computer and looked at the errors, master.
08.05.2020 18:35 # 8
pierson
Master time, but he couldn't find anything ... he doesn't do it all the time ... when he gets up and stops, sometimes when the new gas is bought, sometimes when the gas is low ... I want that role to sound ... even when he goes on the road.
