Help with 206 radiator water replacement?
08.05.2020 18:47 # 1
Barut
Have a good day.
I think about changing radiator water and antifreeze, including the engine block.
How many liters of water does it take in total? If anyone knows, please tell
I am thinking of buying 2 liters of pure water and 2 liters of antifreeze, will it be enough?
Also, what color should I buy as antifreeze, my 2006 model 206 feline petrol. We have antifreeze in blue now. Thanks in advance. Red dream 2014-09-07 03:48:55
08.05.2020 18:47 # 2
suppor
The bidet needs to change in the amount of time you say it.
08.05.2020 18:47 # 3
Barut
Current.
08.05.2020 18:47 # 4
samet206
You do not need to buy pure water from antifreezes that are 3 Kg. You can add the tap water, if you do not remember correctly, you will add 3 kg of reservoir 2 kg antifreeze on top of water or 1 kg antifreeze on top of the water, you can adjust the rates yourself. I am in favor of a change in 2 years, but it is a situation like losing its feature no matter how much it is measured.
08.05.2020 18:47 # 5
Barut
[QUOTE = samet206] You do not need to buy pure water from antifreezes with 3 Kg. You can add the tapped tap water. If you don't remember your vehicle, it was already taking 3 kg. When antifreeze is weakened, you can make a change. I am in favor of a change in 2 years.
[/ QUOTE] It hasn't changed for 2 years, my teacher, I will change it nowadays without going to winter. In other words, we will antifreeze for a total of 3 liters and I have understood correctly in a total of 3 liters of water.
08.05.2020 18:47 # 6
ibanez_022
I bought 106 or 3 liters. came too much. I said, let's not put the tap water. When it mixes with antifreeze, he destroys all harmful elements of water. I said ok.
08.05.2020 18:47 # 7
Barut
[QUOTE = ibanez_022] I bought 106 or 3 liters. came too much. I said, let's not put the tap water. When it mixes with antifreeze, he destroys all harmful elements of water. I said ok. [/ QUOTE] so I am 2 liters of antifreeze to get 2 liters of pure water. Let's get our money safe, not something Thank you, Master.
08.05.2020 18:47 # 8
suppor
What is the price of the antifreeze? Well, the color of mine is not green, there is no shortage. I have been traveling for 10 thousand km.
08.05.2020 18:47 # 9
samet206
[QUOTE = Red dream] [QUOTE = ibanez_022] I bought 106 or 3 liters. came too much. I said, let's not put the tap water. When it mixes with antifreeze, he destroys all harmful elements of water. I said ok. [/ QUOTE] so I am 2 liters of antifreeze to get 2 liters of pure water. Let's get our money safe, not something Thank you, Master. [/ QUOTE]
It takes about 3 liters in total, as well as it should be around 3 Lt in the mixture of antifreeze and water. You can put it in drinking water. You know it, but I think I don't wear it that much, in short, do not get stuck in this kind of things. Just antifreeze and make the water mixture rate good for 2 years. Do not forget to get the air in the system thoroughly, otherwise pure water is normal water, it is not a problem.
samet206 2014-09-09 19:31:58
08.05.2020 18:47 # 10
Barut
Thank you for your interest.
08.05.2020 18:47 # 11
Barut
[QUOTE = suppor] The price of the antifreeze is about 10 thousand km, if the color of mine is not green, there is no decrease, I am going to change it for 10 thousand km. According to the quality, subject to around 10 TL. There is a detailed illustrated topic in the forum for the change. I am looking at that topic, it is not difficult.
08.05.2020 18:47 # 12
suppor
[QUOTE = Red dream] [QUOTE = suppor] The price of the antifreeze is about 10 thousand km, if the color of mine is green, there is no shortage, I am going to travel for 10 thousand km. [/ QUOTE] antifreeze liter is around 10 TL, depending on the quality. There is a detailed illustrated topic in the forum for the change. I am looking at that topic, it is not difficult. [/ QUOTE]
My brother, can you put the link of that topic here?
08.05.2020 18:47 # 13
Barut
[QUOTE = suppor] [QUOTE = Red dream] [QUOTE = suppor] The price of the antifreeze is about 10 thousand km. The "middle" /> [/ QUOTE] antifreeze liter is around 10 TL, depending on the quality. There is a detailed illustrated topic in the forum for the change. I am looking at that topic, it is not difficult. [/ QUOTE]
[/ QUOTE] come on brother
http://forum.peugeotturkey.com/forum_posts.asp?tıd=23736 Red dream 2014-09-12 17:04:57
08.05.2020 18:47 # 14
suppor
It did not open :/
08.05.2020 18:47 # 15
Barut
[QUOTE = suppor] UrgentName: / [/ QUOTE]
I am entering through the wire, I think it is not because of it,
Or so you can google 206 water change to summer 2. Click on the link from the results. Click on the link provided by the master named koliva at the end of the page.
08.05.2020 18:47 # 16
Barut
I think you found no sound :)
08.05.2020 18:47 # 17
suppor
just like my brother if i found it a bit tricky, i dont want to get in trouble like a bit :)
08.05.2020 18:47 # 18
Barut
[QUOTE = suppor] exactly when my brother is a bit tricky when I find it, I do not want to get in trouble like a bit of a bit like it:) [/ QUOTE] I even got it :) but it is really hard.
08.05.2020 18:47 # 19
Barut
. Red dream 2014-09-21 04:31:51
