help trouble starting first friends
08.05.2020 15:23 # 1
kaan__
friends, when I park in a 307 vehicle in the morning or for a long time, when I start for the first time, the car does not work immediately, then I start for the second time. I have this problem like 9 or when I park somewhere for 5-6 hours and get on again, the same problem happens again.
I'm waiting for your help Ağlama
kaan__ 2011-05-06 23:57:21
08.05.2020 15:23 # 2
In sequential system, LPG starts with gasoline at the first starter and switches to LPG after the engine is warmed up.
I think change your gas filter.
08.05.2020 15:23 # 3
metin
If you hold down the lpg button while pressing the mustii starter, it runs directly on the throttle.
08.05.2020 15:23 # 4
metin
If you explain a little bit like kaan__ can you explain it a little like starter or starter, make a squeak (rubbing sound), or start a starter, but the engine does not work, etc. the problem is understood more quickly.
08.05.2020 15:23 # 5
toprakk
1 place does not. it can happen for many reasons. can be from coils. it may be from the spark plugs. It may be from the throat butterfly. it could be from the petrol filter. it may be from the gasoline you use. can be from the tube. can be from injections. sensors. if none of these things may even originate from the brain.
08.05.2020 15:23 # 6
metin
exactly,
explain in detail the solution gets faster
08.05.2020 15:23 # 7
kaan__
friends now, the vehicle is running smoothly in normal daily use, it works without any problem when I park it for 2 hours, and I do not think it will be from gasoline when I park the car in the evening and start it again in the morning because I always buy it from the same place. As if it is in the starter, you can waste the gas without a gas in the car or work like that, but right after that, when I start again, the car is running as if nothing happened ... I did not know how to get a result in the morning by pressing the lpg button ...
I have cleared the throat butterfly for 5 thousand km or so, what happened to me before 1000km, my spark plugs have changed ... I don't know why this is going to happen. thank you ... if there is a solution or what happened, i would like to know how it solved
kaan__ 2011-05-07 16:31:00
08.05.2020 15:23 # 8
kaan__
Friends, pressing the lpg button is okay for running friends ...
sure it is not from the coil;)
08.05.2020 15:23 # 9
[QUOTE = kaan __] friends by pressing the lpg button, it is okay to run the friends ...
If I was at your place, I would have the gas system checked. Relieve the pressure of the gasoline coming to the engine. There may be a problem with the pump.
08.05.2020 15:23 # 10
tufan31
If the vehicle is lpg and you are traveling with less than a quarter of the tank, your gas pump is heated and malfunctioned by drawing air instead of gasoline during the churning in the tank. After a while, it will never work with gasoline. It is stable with experience ... Ağlama
08.05.2020 15:23 # 11
sace
You said your car started 2nd morning in the morning but it is working. Also try this. Make a half contact, but do not crank, turn off and repeat, press the 2nd crank. If it works, it will reveal the source of this problem. Most likely, not enough gasoline can be pumped into the gas automatic at first.
08.05.2020 15:23 # 12
metin
[QUOTE = sace] You said your car started 2nd morning in the morning but it works. Also try this. Make a half contact, but do not crank, turn off and repeat, press the 2nd crank. If it works, it will reveal the source of this problem. Most likely, not enough gasoline can be pumped into the automaton at first. [/ QUOTE]
sensible
08.05.2020 15:23 # 13
kaan__
Yes, I tried it yesterday, I waited a few times before I opened the ignition and waited for a starter. On the day after, I have a look at the gas pump and the gas filter.
thank you very much
08.05.2020 15:23 # 14
nkre52
it happened to me
service software update improved
08.05.2020 15:23 # 15
mustafa486
Did you say that when you press the lpg button while pressing the starter, you are working on gas ?? How do I press the lpg button, while pressing the starter. there is no such button. I mean, I can either gas or gas. I have no chance to hold it down ??
08.05.2020 15:23 # 16
kaan__
If you hold the toggle button when you press the key you use to switch from LPG to gas or LPG to LPG, you can start the vehicle with LPG if you press the starter button while pressing the starter button ...
08.05.2020 15:23 # 17
kaan__
[QUOTE = nkre52]
it happened to me
service software update fixed [/ QUOTE]
I wonder if the software was updated or what I said is just because the software has been updated, I was wondering if they had any other complaints ... they made a software update for him ... Ağlama
kaan__ 2011-05-08 11:58:10
08.05.2020 15:23 # 18
monur
[QUOTE = text] mustii works directly on the throttle if you hold the lpg button while pressing the starter. [/ QUOTE]
A friend of mine, Hyundai Accent Era, was running the way you said, the vehicle (summer and winter) shouldered the injectors of the latest engine. Unless there is a very urgent situation, I think it is one of 9 defective movements. Otherwise, I think the system would work directly with LPG.
08.05.2020 15:23 # 19
kaan__
gasoline pump checked no problem spark plug, coil clean ... trial and error, there are a few more methods last resort software update ... if another friend experiences this problem, maybe i will help you so i write the result here
08.05.2020 15:24 # 20
jamalserhat
I think kaan is facing the same problem when we find a solution or when I find a solution, let's share
Page : / 2
