help took the headlight water
08.05.2020 15:10 # 1
isodogu
Right headlight of my 2006 model 307 car started to get water repaired and started to get water again 1 month later. I renewed the headlight, it rained, the result was water again, did you encounter such a problem? what should I do
08.05.2020 15:10 # 2
trtolgi
my friend had been with me a few times.
08.05.2020 15:10 # 3
isodogu
[QUOTE = trtolgi] my friend had been with me a few times.
The headlight has just changed, but I'm still a caregiver
08.05.2020 15:10 # 4
Muhammet CAKIR
IF THE PROBLEM IS NOT SOLVED, TAKE TRANSPARENT SILICONE TO THE EDGE OF THE NEW HEADLIGHTS
08.05.2020 15:10 # 5
formulaone
I think if you are having a problem with headlight, go to the hardware store, black dayson al silicon or something, my friend is losing your water when silicon is gone. black dayson after cleaning, but you have to close all the holes then the result is super
08.05.2020 15:10 # 6
xdesign
I have that same problem. When I removed the headlight, I saw one of his feet cracked. I siliconed black, but it's still the same. I'm not going to fall for an Angel.
08.05.2020 15:10 # 7
oguzhan29
Silicon brush around the sister, you don't have any problem getting water well.
08.05.2020 15:10 # 8
isodogu
I talked to the place wearing the headlamp, they will look at it and let them apply what they say to the masters.
08.05.2020 15:10 # 9
peugeotefe
Open the cover on the back of the headlight and then combine 2 pages of newspaper paper and tape with the headlight to cover the headlight, then leave the headlights on for 1 hour.
