Help to install 407 xenon
08.05.2020 18:12 # 1
06smt06
I would appreciate it if anyone knows or can solve it
my car 2006 407 is currently xenoon but it has not passed through the inspection and will repeat, of course I will attach the normal bulbs and go, no problem. but if I re-install the xenon later, is there anyone who knows or is able to solve faults like fuse box wiper motor?
08.05.2020 18:12 # 2
herry
I don't think it will be a problem if you plug it back in if it didn't fail before the test. Get well soon.
08.05.2020 18:12 # 3
06smt06
Yes, I did not have any problems at the moment, when I bought it, I was on binyour for about 1 year, but I will take the examination tomorrow, but he says he will hurt if he does not know, he said, "I do not know if they said no nickname." I am researching but a lot of things are being used for commercial purposes.
08.05.2020 18:12 # 4
mistercasper
The xenon problem is really annoying ... I know someone like you who disassembles and reinstalls it before you examine it, probably yours will not cause any problems, but it seems as if it is still risky ... By the way, I have 407 brand of xenons and I want to wear xenon too ...
08.05.2020 18:12 # 5
burglar08
Unfortunately, the live bomb is xenon in 407s. You will say that nothing happened in 1 year, and no more. Unfortunately, this job has an invisible face and it is not clear when it will happen.
For 407 in my signature, the year of my speech was past, but one day the wipers gave their heads in seven services.
08.05.2020 18:12 # 6
06smt06
Before I wear it, I will investigate a little more and go to the electricians and walk around.
my xenon larri brand GT hıd bi xenon
The xenon is very nice on this vehicle. I made the American parking module in the bidet headlight, the xenon is not satisfied with its image, it shows itself differently.
I think someone who can solve it will probably not be a troubled situation, it seems like it will not be solved. someone finds someone
08.05.2020 18:12 # 7
06smt06
american parks or something :)
08.05.2020 18:12 # 8
herry
I do not know the system of the 407, I do not know how he wore it before. I think if those who use it say the problem comes out, stay away.
08.05.2020 18:12 # 9
Oh my brother, my sister does the same thing. Maşallah it was very stylish. Actually, you helped me without noticing. I couldn't decide how I wanted to make an American park for my car, but the image was a number 10 image.
In the meantime, look over the ballast boxes of the xenon sets in your vehicle, if it says Canbus, it is okay, but if it does not say Canbus, you are holding the time bomb in your hands. Be sure to take it off and take it from the set that says canbus. You won't have any problems with xenon systems with Canbus.
08.05.2020 18:12 # 10
06smt06
Wink Thank you, first of all, yes, it looks very nice and looks very successful :)
If we come to xenona, what does it mean, what canbus is and what is the author ballast
08.05.2020 18:12 # 11
mistercasper
Did you get the xenon?
08.05.2020 18:12 # 12
06smt06
No, I haven't appreciated yet, I am indecisive :)
08.05.2020 18:12 # 13
mistercasper
Did you look at the Canbus event ... I think they are following the role together and I think you should not wait in your hand empty xenon
08.05.2020 18:12 # 14
[QUOTE = mistercasper] Did you look at the Canbus event ... I think they are following the role together and I think you shouldn't wait in your hand xenos [/ QUOTE]
The new generation canbus system is already relay. This time the relay will not be installed, you will burn the car from the excess voltage.
If you write the brand model of the kit used here, I will see if it canbus.
In some canbus system xenon kits, except for ballast, a small black box is connected, namely ballast box + black square box and then headlight bulb. In some, the circuit in that box is inside the ballast case, but if the canbus ballast is already written on the promotional label on the case, we will see if it says canbus.
08.05.2020 18:12 # 15
mistercasper
moondust do you use xenon
08.05.2020 18:12 # 16
It was on all my vehicles. I haven't put it on yet.
08.05.2020 18:12 # 17
06smt06
Hyr, I do not understand before, so when I bought it was rakisi on top and it was not a canbus and how it did not cause a malfunction.
08.05.2020 18:12 # 18
[QUOTE = 06smt06] Hyr, I do not understand before, so when I bought it was rakili on the top and I did not have any problem in the way of the canbus or something.
You are right about that, I see him very hard, the headlights are very weak. It is not clear when this fault will occur. You can have a problem at any time. If there is no canbus indication in the kits, please show your kit to a robust auto electrician or an authorized peugeot dealer. Do not overdo your head. It's a pity.
08.05.2020 18:12 # 19
06smt06
I have a critic, let's go to the tuesday, let's see what the comments will be
