Help the tire to shake and rub.
08.05.2020 13:58 # 1
Hi friends;
first of all let me state my springs FK brand cut and shock absorbers 50% hardened.
My first problem is that the vehicle vibrates. balancing was done, but tremor continues from 110-120km / h. I think it is due to the difference of the undercarriage.
The second problem is that the right front tire constantly rubs. As I hit the "garc gurc" in the smallest hole, my pain hurts = (the rubber hood is not rubbing the inner part of the dodiks, and so to speak, he finished my tire, which was only 2 months old, even seven. When I put on the spare wheel and went to the tire, he said that the tire did not break out, but I checked the tires every 3-4 days.
I expect the help of my friends from my friends who have previous experience in this matter,
Best regards, good forums ...
08.05.2020 13:58 # 2
sinan-s
Get well.I had this kind of tremor in me..It got better after making the front team.
08.05.2020 13:58 # 3
sam106
First of all, I do not do the right and left right. I do not do it right and left. I have to cut it a little bit. You have to cut it a little bit. It is plastic. It is hard to cut it with other rounds. Smile I don't know much about tremor, there is no plateau lax but
08.05.2020 13:58 # 4
[QUOTE = sinan-s] Does it prevent too much? I wonder .. [/ QUOTE]
we are doing a little bit of excitement, but at the end of the day we have to endure something we need to endure = (
08.05.2020 13:58 # 5
hasimayaz
There may be secretion in the rims. It is useful to press the balance from the front and the press. For rubbing, you will need to grind the dods a little.
08.05.2020 13:58 # 6
[QUOTE = sam106] first of all, I do not do the surtme full right left, I have to cut it a little bit, I have to cut it a little bit, it is plastic, it is difficult to cut it with another round, it is noticeable to set the pit, it is the attention to the sets Smile I don't know much about tremor, there is no plateau lax but [/ QUOTE]
we cut it down but the bonnet comes out from the bottom napcazkiii :)
08.05.2020 13:58 # 7
sam106
[QUOTE = ANDAY] [QUOTE = sam106] I do not do the right right left, I have to cut it in a little bit, I do not do the right right left right, you have to cut it a little bit, it is plastical, it is difficult to cut it with a different kind of attention. Smile I don't know much about tremor, there is no plateau lax but [/ QUOTE]
[/ QUOTE] How many of your rim tire sizes do you have?
08.05.2020 13:58 # 8
[QUOTE = hasimayaz] There may be runout on the rims. It is useful to press the balance from the front and the press. You will need to grind the dods a little for rubbing .. [/ QUOTE]
There was no problem before pressing the car, but now I do not keep it in balance, I'm going like Azer Bülbül inside the vehicle: D
08.05.2020 13:58 # 9
195/45/15
08.05.2020 13:58 # 10
sinan-s
It seems that my avoids are higher. As seen in the picture. If your lower is lower, it can rub.
08.05.2020 13:58 # 11
sam106
Do you take it from the same one too? Smile
08.05.2020 13:58 # 12
sam106
[QUOTE = sinan-s] My avoids are higher understood ... As seen in the picture .. If your lower is lower you can rub ..
[/ QUOTE] sinan big brother what a gush like this yellow Wink
08.05.2020 13:58 # 13
[QUOTE = sam106] Do you get it from the same bin, my card, how many cm springs Smile [/ QUOTE]
FK had a bow, a pod did not fall as I want,
this springy state;
this is the current state;
08.05.2020 13:58 # 14
sam106
My friends are afraid there is nothing to be afraid, but the dream is so sweet Smile I do not cut bras dha.
08.05.2020 13:58 # 15
Thank you for the comments. Quikci rushed to help immediately.
08.05.2020 13:58 # 16
sam106
[QUOTE = ANDAY] thank you for the comments quikci rushed out to help immediately =) i don't use bola bole, i don't think your car is low anymore . com
08.05.2020 13:58 # 17
okay ..
08.05.2020 13:58 # 18
entel
I had the tremor as well.
after trembling the rims and changing the front and back, there was no trembling.
But because the wheels and the tire are larger than the original, the Balance deteriorates much faster than other vehicles.
Therefore, the car is out of balance and vibrates at certain or uncertain speed limits.
For example, it is interesting to me that it was shaking between 90-110.
08.05.2020 13:58 # 19
sinan-s
Anday is the ideal size like mine before the first picture is cut.
08.05.2020 13:58 # 20
sam106
yellow too deep test brother die yellow yellow science device side Tongue
Page : / 2
