Help the fuel needle to come to zero suddenly
08.05.2020 19:43 # 1
mustimed
Good evening, friends. The trouble I have had for a few days is that the fuel pointer suddenly drops to zero after starting the car and then gradually restores it within 15 minutes. I always use my vehicle on a half tank. What is the solution of such a problem?
08.05.2020 19:43 # 2
mustimed
Friends, this problem does not only sound from anyone I've had in turkey benmi
08.05.2020 19:43 # 3
Teacher, the problem seems to be a situation related to the chaperone.
08.05.2020 19:43 # 4
mustimed
You say it can't be for another reason, brother
08.05.2020 19:43 # 5
xdesign_206
If a situation related to the float is calibrated completely, the problem is solved.
08.05.2020 19:43 # 6
mustimed
Thank you for your interest
08.05.2020 19:43 # 7
gogly35
If the vehicle has LPG, the fuel gauge can fall as if there is consumption due to wheel rotation, and then it can go back to the normal level. Also, as friends say, there may be a float problem.
08.05.2020 19:43 # 8
tamers_57
Absolutely buoy. If you are close to Bostancı district, I recommend Tek Oto Servis.
