Help the clattering sound coming from behind.
08.05.2020 19:08 # 1
aliyurttakal
Hello friends,
I am using the 2002 model 1.4 Colorline, a new problem is coming from the back, especially in the humps and the cobblestone style, there is a constant rattling noise from the back, which makes me very uncomfortable, and when I show it to the services, the torsion needs to change, a different service needs to change the rear shock absorbers, and they charge 500 600 TL. Obviously, it is obvious that they shake because of their attitude towards lacquer. As far as I investigate, it is a chronic problem torsion event, but since I took the car, it has been 1 month, the sound has only been 1 week and I suddenly leave the car. I used excessive contempt for 1 week after the sound, if there was torsion, more trouble would occur, but there is no change in the sound. Can I get help from the same level of services before I take money in vain, friends, what are the voices in 206? can you help me.
08.05.2020 19:08 # 2
serky54
Take one wd40 in the hand of my brother, first spray the rear suspension with oil, then apply it to the rear seat hooks (you can drive it in gress oil) and the 80-90% of the problem will be solved with the wd 40 and the plastic parts that touch each other at the rear seat belt exit point.
I had the same problem, I don't have it right now :)
08.05.2020 19:08 # 3
206x-line
I can do it in a few things. I have been my old car.
1: it may come from a trunk lock (either exchange or getting a little down)
2: it can be jacked up inside the tire (it can be removed and compressed by inner tube)
3: the back seats can come from the lock seat (it will work to fit the tape to be fully seated)
4: If there is no gap in the torsion or not (there is a torsion shaft, the thin bar is located between the two wheels, remove it already, this sound is a hard kick to the rear wheel, you can pull the metal sound shaft and attach a hose to fit it. I reached the definitive solution by wrapping a cloth tape and I hope it works well.
08.05.2020 19:08 # 4
ALLEX
[QUOTE = serky54] bro, take one wd40 in your hand, first spray the rear suspension with oil, then apply it to the rear seat hooks (you can drive it in gress oil) with 80-90% of the plastic parts that touch each other at the rear of the rear seat belt outlet. your problem will be solved
In 2008, I bought zero fever 206. A week later, the creaking sounds began to come from behind.
the service said, `` your ears are exaggerating. ''
I found the problem (Absolutely from the back seat hooks)
I solved the solution like a joke but by making something like Teflon material in the lathe and compressing it there.
I recently bought 206 sw again on the same day I solved that creak with my old method :) Clap
You can solve the hard plastic pipe by cutting it from the section and passing it to that area.
08.05.2020 19:08 # 5
ceteris paribus
If it sounds like a squeak, there is a high probability of torsion. I also had a torsion problem. When I first buy it, it will cost you 500-600 TL. If it sounds like a tukh, it is like a friend's luggage cover, etc. is due to reasons.
