Help the back column !!
08.05.2020 15:28 # 1
Before my friend sold the vehicle to me, he had a column installed on the back doors and the jack on the back door pipes where the installation he came from had a jack outlet for the back door, and they pulled the cable from those jacks, but when you turn up the sound a little too much, the columns start to sizzle. They said that it is necessary to go to the authorized service and connect to the computer and open the rear column settings. Also, while mixing the tape's settings last night, I noticed that the front and rear column settings are not in the settings section and are not in the rds, but I know that there is rds in the tapes of our vehicles, do you think this is true ???
08.05.2020 15:28 # 2
rds is an old feature. the absence of crazy. I have no idea about the other subject
08.05.2020 15:28 # 3
bahadır ... now I cannot say if there is any rds in the tape of the 1st vehicle .. but definitely know that even in the most devastated tape there is definitely a column separation setting ... so you can give the sound to the front, ster back or all ...
2. Normally most vehicles do not have a rear column and are ready to replace it ... anyway .. now. cable from the audio output of the tape to the front columns and connected ... ok until here .. if the rear columns come from the same place, then the cables will be both weak and of poor quality. even if you open the sound loudly and listen to it for 5 minutes, it will light the sound output of the tape ... as far as I understand, my uncles tied 4 columns to a single output. connect ..... let's come to the issue of rds is not that important.
08.05.2020 15:28 # 4
Muhammet CAKIR
In the tape recorders that came out in 95, there are only two column outputs in some of those who have cassette players. there may be exploded or it can be very loud and it can be attached to the speaker. Let's go back to your location.
08.05.2020 15:28 # 5
I found out that there was a jack output for the rear column connection on the rear doors, and there was no connection from the front speakers connected to them and 20 days ago, the pioneer column was installed both in front and behind.
08.05.2020 15:28 # 6
Muhammet CAKIR
the sound needs to be good, then use the bass setting at 0, use the treble setting at 3-4, try it so that the bass can creak
08.05.2020 15:28 # 7
[QUOTE = Bahadır32] I found out that there was a jack output for the rear column connection on the rear doors, not connected from the front speakers connected to them and 20 days ago, the pioneer column was installed both front and rear. [/ QUOTE]
ok. That means the front and rear exits are separate ... then there is no problem in the exits .. 3 options remain in this case ....
1..Find the settings of the tape before ... it is definitely there .. impossible to not .. bass stay at 0, treble up to 4 ..
2 .. If the problem continues, I have to look at the columns, if there is an eruption, you need to change it.
3. If there is no break, +/- connections are wrong. Probably ... there is no service situation .. while the fragmentation stops and stops ..
Go to the auto tape recorder, he will finish his work in two minutes ... If I have time, he will come, I will even look ... Sırıtma
08.05.2020 15:28 # 8
God bless friends, thank you for your help. Good Friday everyone.
08.05.2020 15:28 # 9
[QUOTE = Bahadır32] God bless you guys, thank you for your help. Good Friday everyone. [/ QUOTE]
What do you mean, buddy, we will be happier .. good friday ..
08.05.2020 15:28 # 10
Guys, I just mixed up the tape and I really need to go to the service and have it turned on because it has a right-left setting but no front-back setting and there is also an rds button on the tape but I don't press it persistently: D is not working despite D. Audio 25-26. When I get to the level, the incredible sizzle starts as if the columns are erupting. As my friend says, they need to go to the service and open the settings. The brand of the tape is clarion.
08.05.2020 15:28 # 11
it is a very interesting situation ... I don't understand.
08.05.2020 15:28 # 12
Well, I couldn't solve the situation, however, the doctor of this profession, on the sound system because it blows in the prof. I have a brother, I will go to him and ask him.
08.05.2020 15:28 # 13
[QUOTE = Bahadır32] I swear I couldn't solve the situation, but the doctor of this work on the sound system because it is early in the prof. I have a brother, I will go to him and ask him. I will go to the service and know how much I will know until the faint fails. [/ QUOTE]
I swear that I am a blow, but I didn't hear someone ... I had the pionner osman I know, the room disappeared and gone from the market.
08.05.2020 15:28 # 14
There is a road to the Esenler subway from the bus station. When you enter that road, there is a person who is a man who makes a car sound system next to 2-3 shops next to the left and next to 2 shops.
08.05.2020 15:28 # 15
ok ok ok ok .. ok I remembered now..safety is working with a sponge room .... i will stop by i look at how is crafting ..
