Help replacing the radiator seal .. !!
08.05.2020 20:05 # 1
dejawu1978
Hi, friends, we put antifreeze for winter care, but what happened and I said that the antifreeze water started to flow to the driver's side.
ORING so ... in particular if I take this ORING and can I change it myself
I throw a picture of the piece under it to get something clearer, with this, I used to tighten a little bit before going to the repair shop from the part of the capped part, that is, where the 8/9 bolt was, but I guess you still missed the gasket feature ...
In short, if I take this oring and I can do it, I can do it with a bite or chest Confused
08.05.2020 20:05 # 2
dejawu1978
I will buy a product boum ..? : Http://www.peugeotturkiye.com/peugeot-206-1.4-benzinli-devirdaim-conta of
08.05.2020 20:05 # 3
Teacher, this is not the product you will buy. Unfortunately, you need to get the complete set of the picture you put on the top, or if you want the original gasket or you can remove the gaskets and replace them with a similar gasket in auto hardware shops. you can change it without removing the chest. I removed my cat 4-5 times :)
08.05.2020 20:05 # 4
dejawu1978
dear moderator um when i find that gasket somehow i want to disassemble it, it is important to get rid of this problem and save me from this trouble and tell you in simple and plain language they said effort 300 tl blood sugar fell officially
I think our vehicles are the same model .. I have 2 screws in mine. When I take them apart, take the old gasket and insert the new one and the event will be finished. thank you in advance for your cvp Wink
08.05.2020 20:05 # 5
Let me tell you, first of all, you have to unscrew the hoses that go to the calorie in the engine, engine section. then we go inside. There is one rivet on the left door holding the front chest, it is necessary to tear it off. Then you will unscrew the gas pedal. you unscrew one screw holding the double plastic pipe that you put on the picture. After unscrewing the screws connecting the heater core and that pipe, you will save the heater core from your nails, then slowly and by cascading it, the pipe and honeycomb will be separated from each other. I add the topics related to the subject.
The logic for this 307 is the same, but removing the honeycomb takes a bit of effort.
my http://forum.peugeotturkey.com/forum_posts.asp?tıd=20250&title=sogutma-suyunun-aracin-icine-sizmasi-proble
for buddha 206
I http://forum.peugeotturkey.com/forum_posts.asp?tıd=38402&title=206-kalorifer-sokumu-resimlicozul
08.05.2020 20:05 # 6
dejawu1978
Halal be good to you :) Having a picture of health in your hand made my job much easier ... oddly, the water is leaking when the water comes to a minimum. Smile
08.05.2020 20:05 # 7
you are welcome hodja we need to thank our members who took photos and shared. Since the cooling water system is closed circuit in new generation vehicles, the heated water is expanding and there is a leak out there. Then, when the water level drops to a certain level, it does not decrease when the pressure is not too high.
08.05.2020 20:05 # 8
samet206
Every work has a workmanship, and in the market they usually change the honeycomb completely, they do not leave it to chance. Therefore, the price is fluffy. Removing the honeycomb can be done if you think I can overcome it. If you have a place, it will be more comfortable.
samet206 2016-12-20 20:13:06
08.05.2020 20:05 # 9
erendumlu
Unfortunately, if it started just after antifreeze, it is not from oring. In systems used only with water for a long time, a hole is formed from the weakest rusty area with antifreeze. In your car, this lucky piece of heating honeycomb is out. He could come out on the radiator. Kismet
08.05.2020 20:05 # 10
dejawu1978
well, I observed quite a bit, I touch it with the finger on the bolt connected to the double pipe in the picture that combines with the honeycomb. There is a droplet already.
08.05.2020 20:05 # 11
dejawu1978
I went to the industry today, a competent person recommended a master, changed it in 2 hours, used the gasket, even the liquid gasket. Wink
08.05.2020 20:05 # 12
I like that your problem is solved, hodja Thumbs Up
08.05.2020 20:05 # 13
Haktan
I wonder which master you went to, I am also suffering from the same problem
08.05.2020 20:05 # 14
Eses li kaptan
the same thing happened I could say right from the master with the 307, we put antifreeze in the water, but no need to disassemble the 307 2004 model vehicle from the left side of the scilıyo honeycomb and interconnection pipe orsda
However, if the pipe is cracked or broken, it is very difficult to find it since 5 days.
Servis says 630 TL and says I don't have it. Ankara istanbul izmir.
08.05.2020 20:05 # 15
omerb
I found this pipe from abroad. But I don't know the shipping cost. I'll ask for you. Add your own. Does this part have a code? No mistake. I think these are manufacturer companies.
08.05.2020 20:05 # 16
Eses li kaptan
307 heater radiator pipe 2
Passing stock code as 6448k1
I would be very happy if you find my teacher
08.05.2020 20:05 # 17
ismailkaya
The repairman, whose friends do his job, is now rare for a 10 lira gasket change. The thieves who want to be inserted and ask for 300 500 1000 TL are many. Note. Do not trust those who leave beards, friends. Ask for the bill of everything, ask for the bills of the parts that change, get the invoice of every piece they call new tactics.
08.05.2020 20:05 # 18
omerb
I contacted someone. Let's see if it will adapt, it will give a price. I'm gonna inform you
08.05.2020 20:05 # 19
omerb
I found the piece. The manufacturer gave information. I am learning the shipping charge. I'll take care of him if it is worth bringing.
08.05.2020 20:05 # 20
fsahiner
Where did you find the track 6448k1, that part of my 307 was broken yesterday. I would be glad if you could help.
Page : / 2
