help please. engine brain or gasket burning?
08.05.2020 16:23 # 1
spilmac
friends, I would like your help. I have 307 teachers in batman. 2002 model XR.
While driving on the highway with 170-180, the engine malfunction lamp came on suddenly, it wrote "catalytic cpnverter fault" and then it wrote "antipolution fault". the car is walking but I have to make a high speed to walk. When the car drops below 15, the vehicle stops immediately. (no temperature)
then they said from the spark plug. spark plugs changed, the problem did not go away
they said coil. they changed the coil, the problem did not improve.
said electronic system. They said we would change the brain of the car. but they are not quite sure.
08.05.2020 16:23 # 2
06OzGuR06
Was the catalytic converter checked?
Did they measure the cylinder compressions? Perhaps a cylinder may not create compression, which indicates the gasket.
Should the injection system be checked? Why is the brain changing so I think this is the last thing to be done?
08.05.2020 16:23 # 3
spilmac
converter was not checked.
cylinder compressions were not measured.
injection was not checked either.
they looked at the spark plug-coil-electronic parts and the brain since there was trouble in ignition. . They said the brain will change.
08.05.2020 16:23 # 4
06OzGuR06
I think these should also be looked at because the error of combustion points to these situations.
adventure peugeot 2011-11-22 00:58:24
08.05.2020 16:23 # 5
spilmac
yes it is falling. it works by singing. the tachometer also stops when it drops below 15.
08.05.2020 16:23 # 6
06OzGuR06
Then, as I said, the injectors should be disassembled and the compression should be measured. I would recommend that you check the spark plug coil all changed. I think that if the car brain is damaged, the cycle will not exceed 3000 cycles or some functions will not work at all.
08.05.2020 16:23 # 7
spilmac
araac 3000i is comfortable. He's already hitting 110-120. but it stops immediately under 1500. I am very afraid, I do not know what is not. I guess it will cost me a lot.
08.05.2020 16:23 # 8
06OzGuR06
Because you say it works by singing, I think of an injector or compression. The computer also gave a burning error.
08.05.2020 16:23 # 9
spilmac
You say it's not a brain.
08.05.2020 16:23 # 10
06OzGuR06
I am not saying that it is not certain.
I think these two should be looked after and if everything is normal then the decision should be made because the brain is not cheap as far as I know. I do not think it will be below 1000 TL.
08.05.2020 16:23 # 11
spilmac
No, they didn't look at him either.
08.05.2020 16:23 # 12
06OzGuR06
So my guess is that you have a look at these.
I hope you get out of it at a low cost.
adventure peugeot 2011-11-22 01:41:33 < / editdat a>
08.05.2020 16:23 # 13
okan77
Fuel taken from different places can give you the errors you specified.
08.05.2020 16:23 # 14
spilmac
& Nbsp; bro, this problem happened in lpg. does not notice gasoline & nbsp; or be lpg & nbsp; spilmac 2011-11-22 09:28:52
08.05.2020 16:23 # 15
spilmac
Does anyone know :(
08.05.2020 16:23 # 16
yavuz25
It is most likely that the catalytic converter is full.It will either be removed and removed, or that part will be removed completely, and a muffler will be installed to prevent sound change. gif "height =" 17 "width =" 17 "border =" 0 "alt =" Wink "title =" Wink "/>
08.05.2020 16:23 # 17
06OzGuR06
http://forum.peugeotturkey.com/forum_posts.asp?tıd=18913&title=antipollution-fault-zm
08.05.2020 16:23 # 18
emin15
If the ignition coil is installed at zero instead of pulling out, the brain is probably defective, the brain is controlling the coil. If there is a problem with the gasket or catalyst, your vehicle will run at idle. Otherwise, it will not work.
08.05.2020 16:23 # 19
spilmac
As you said, brother, the car doesn't work at idle. instantly halts the age of thought. & nbsp;
08.05.2020 16:23 # 20
monur
The 2000-2004 model Ford Focus has a similar problem with the chronic problem. The coil returns to normal when the coil changes, I couldn't understand where the change of EGR came from. It is simple.
Page : / 3
