Help please
08.05.2020 15:35 # 1
026206 HDi
Hi ,
2005 model 206 HDi X DESIGN / 88.000 KM / vehicle does not work at all, lights and all systems are normal, but there are no clicks on the engine, there are no snaps, the reason may be, I suspect the starter's coals, can it be, emergency aid
the albaydemirc 2011-06-10 13:23:20
08.05.2020 15:35 # 2
Kemanyak
If you suspect coal, hit it with a long iron rod 3-4 times on the starter. It may work but this is a temporary solution. Also check the battery connection.
08.05.2020 15:35 # 3
the night of our friend came to the press just like the car is not pressing but all the lights are on, the cable of the mars motor is disconnected
08.05.2020 15:35 # 4
I do not think you will have a battery-related battery because the lights are on, you have the same problem.
08.05.2020 15:35 # 5
026206 HDi
all systems and wiring are normal, but no clicks
08.05.2020 15:35 # 6
Baybars
The same incident had happened to by_ersin, the lights were on the boards, the starter did not click, the battery changed, and it was corrected.
08.05.2020 15:35 # 7
disconnect the terminals of the battery for at least 1 hour ... then plug it back in and try Sırıtma Don't fade the electrician like me ... if it doesn't improve, go to the electrician ...
08.05.2020 15:35 # 8
026206 HDi
I just changed the battery, you don't have a wall in it
08.05.2020 15:35 # 9
[QUOTE = 026206 HDi] I just replaced the battery, you have no walls on it [/ QUOTE]
According to the rules of the forum, my friend must first introduce yourself in a proper way .........
Also, wherever you reside, can you write the location in your profile and sign your vehicle information
the cecol 2011-06-10 14:12:40
08.05.2020 15:35 # 10
metin
[QUOTE = CeCoLi] [QUOTE = 026206 HDi] I just replaced the battery, you don't have a wall in it [/ QUOTE]
Just share your information that our friends around you will help you more.
08.05.2020 15:35 # 11
goktug
friends know the same problem happened to me yesterday. the problem was that the starter cable was loosened. the problem is the same, he says. it is about starter motor ...
08.05.2020 15:35 # 12
Baybars
Then the coal of the starter engine is left alone.
08.05.2020 15:35 # 13
026206 HDi
cavalier problem in coal
But what is the reason for this?
08.05.2020 15:35 # 14
My friend did you open another topic, I was silent because the process was completed. you can write your completion here ...
08.05.2020 15:35 # 15
026206 HDi
Unhappy Excuse me,
the problem is solved, but what is the reason
08.05.2020 15:35 # 16
026206 HDi
THANK YOU VERY MUCH FOR EVERYONE
08.05.2020 15:35 # 17
Unhappy Excuse me,
nice if the problem is solved. but if you are asking us the reason for this I couldn't understand Confused
08.05.2020 15:35 # 18
026206 HDi
I actually wanted to ask about the life of coals
08.05.2020 15:35 # 19
Commanders are the parts that work by sliding into the collector of the alternator. There are vertebrates based on lectures that are not connected to use etc. It is difficult to make a comment, such as km of average water.
