help please
08.05.2020 17:23 # 1
theyet
friends 2005 peugeot 307 xt user the vehicle is at 50.000, the system is in line.
I have been to the industry twice for the same problem for the last few months, I need your help, share your information . When the vehicle does not start for a long time (for example, from evening to morning), the vehicle does not start in one starter. He takes it on the second or sometimes third, after 1 minute after idling, he stops by kicking like fuel does not go. anyway, he feels as if he doesn't stop eating full gas in 1 minute. No, let's not idle and let's go, let's say 50-100 meters away, I will stop at the lights, press the clutch, the gas hand stops to zero immediately. It happened 2-3 weeks later. the two said, let's clean the throttle, but if the problem persists, they said let's change it, whatever they cleaned the throttle problem was resolved 2-3 weeks later the same problem. "Angry"
1) Is there any intellectual knowledge about the problem or has it happened before, I wonder if it's a major malfunction? & Nbsp;
2) How do I change the service and take it to the authorized peugeot service?
08.05.2020 17:23 # 2
There are a few things that can be done to find the problem. First, connect your vehicle to the computer and see if there are any faults. If everything is nomal, I have two suggestions. The first is to test your vehicle with a throat butterfly that you are sure is working as a night. Sometimes it is useful to clean the throat butterfly, but sometimes there is a problem with the stepper motor that unfortunately it does not go away with cleaning. 3. I suggest you the status of your battery. If your battery is a bit old, try it with another battery in line with the possibilities.
koliva 2013-02-24 10:22:10
08.05.2020 17:23 # 3
theyet
I don't think it will be from the battery because it has an inn when it is working or if you feel the battery has difficulty, it does not happen, it doesn't clog like it does not go away if the vehicle is kicking after running, it is not possible that the battery is not possible unless there is a problem in the lights or something.
< div> does not give any error when the car is connected to the computer. As I said, my complaint was over, but it has been renewed, do I need to change it, and it was very expensive, I was depressed :(
I'm going to investigate the stepper motor.
thank you & nbsp; koliva & nbsp;
< br>
are there any friends who have other ideas and knowledge ??
08.05.2020 17:23 # 4
_ali_
I solved the problem of not working in the morning by taking fresh gasoline and riding on gasoline for 1 day, and a problem similar to stopping was resolved with throat butterfly cleaning. But you may have a very different malfunction, I still recommend you to try it.
08.05.2020 17:23 # 5
kaf_kef42
I had the same problem in opel tigra & nbsp; & nbsp ;. . . I changed the coil spark plug every year and when I change it twice, the same problem continued after two months, sometimes it doesn't eat gas, sometimes, as you said, both third contacts are working when it is loaded into the gas (sometimes these misfires are like the engine part will fall down on the ground) is stating. . . .
The coil called you will change, then the same coil will be original, they will say that the vehicle does not lift, you will install the original one and the butterflies will be cleaned again. . . they will say a ton of things, but the vehicle does not have that much cost. . . & nbsp; I went to konya after a full year with this problem but only a master said. . .. I reset it didn't do that again. .. & nbsp; so what I am talking about is that I wish you to take into account what my distress is. . .
but first make the gas adjustment before you pay. . if it does not pass, search for what I say
kaf_kef42 2013-02-25 13:47:26
08.05.2020 17:23 # 6
theyet
throttle cleared 2-3 weeks no problem now happening again. The interesting thing is that something is being done, the problem is solved and then it happens again. Bide had said let's change in our last talk.
08.05.2020 17:23 # 7
theyet
friends I have been using the gasoline for 5 days and there is no problem, I think all the complaints I have mentioned were from the tube. On the other hand, I am happy actually I think it is a simpler and inexpensive problem.
thanks in advance ...
