HELP PLEASE
08.05.2020 16:41 # 1
HaSHuS
good night i have a peugeot 307 hdi 90 hp 2006 vehicle and it is saying "COOLANT LEVEL TOO LOW" while it has been driving for the last 1 week. I looked at the engine water, there is no deficiency, I am waiting for your help.
08.05.2020 16:41 # 2
We would appreciate if you read the topic I gave before opening the topic ..
08.05.2020 16:41 # 3
HaSHuS
okay i opened that subject ..
08.05.2020 16:41 # 4
[QUOTE = HaSHuS] okay I opened it on the subject .. [/ QUOTE]
Thank you .. Experienced knowledgeable friends will help you soon .. & nbsp;
08.05.2020 16:41 # 5
istanbullu_3886
There is an oxygen sensor in the diesel vehicle & nbsp; i didn't hear but
08.05.2020 16:41 # 6
istanbullu_3886
this is not an air flow meter brother
08.05.2020 16:41 # 7
HaSHuS
Well, I wrote the text on the screen.
08.05.2020 16:41 # 8
istanbullu_3886
sorry brother i confused the issues it says it is very missing in the article check the days and the water i think but i am not sure
08.05.2020 16:41 # 9
HaSHuS
water level looked good but glar ?? i don't understand brother
08.05.2020 16:41 # 10
A warning that the engine coolant is running low. If the coolant level is normal, then first you need to look at the sensor when you get that level. The sensor is attached to the container in which you fill the water. Remove the hose under the cabinet and drain the water. Then you can see the sensor. Let's see if there is a clean up first.
08.05.2020 16:41 # 11
HaSHuS
let me try it, there is no other more serious problem then
08.05.2020 16:41 # 12
Cmoss06
Look at the sensor in the radiator replacement water tank, it has trouble.
08.05.2020 16:41 # 13
ismailkaya
the coolant level says too low & nbsp;
08.05.2020 16:41 # 14
ismailkaya
the coolant level is too low I think the sensor does not see the room alerts you from the trip computer
Reviews
08.05.2020 16:41 # 15
sahinsenturk
Hello
I have the same problem, but is there any friend who can solve this issue? This warning usually appears in the morning and does not give any more warning after 1-2 minutes.
08.05.2020 16:41 # 16
[QUOTE = sahinsenturk] Hello
I have the same problem, but is there any friend who can solve this issue? Generally, this warning appears in the morning and does not give any more warning after 1-2 minutes. Check the level of antifreeze. If you park your vehicle up and down, the service may give a reduced warning to the customer because water is not coming. & nbsp;
