help please. 307 new cases are giving error.
08.05.2020 16:32 # 1
muratoner
& Nbsp; & nbsp; Hello friends.I have a problem.I would be glad if you helped.I mean the 307 hdi 2006 model premium, the light in exclamation light in the triangle for the first 15-20 seconds when I put the ignition on and it gives `` remote control battery flat '' warning on the screen. Although I changed the battery of the controller, this error did not go away.
Thank you everyone.
08.05.2020 16:32 # 2
ibrahim YILDIZAK
I suspect the charger & nbsp;
08.05.2020 16:32 # 3
yavuz25
[QUOTE = is Muraton] & nbsp; & nbsp; Hello friends.I have a problem.I would be glad if you helped.I mean the 307 hdi 2006 model premium, the light in exclamation light in the triangle for the first 15-20 seconds when I put the ignition on and it gives `` remote control battery flat '' warning on the screen. Although I changed the battery of the controller, this error did not go away.
Thank you everyone.
welcome to the pevgeot family first. Replace the remote's battery with the original. It will be 99.9% improved. = "Wink" title = "Wink" />
yavuz25 2012-01-16 22:39:52
08.05.2020 16:32 # 4
muratoner
The result did not improve.
08.05.2020 16:32 # 5
atakanka
I got the same malfunction when I went to sport the other day. but when I got into the car the next day, there was no warning. I guess I will have to change the battery of the car's control for 2 years soon.
08.05.2020 16:32 # 6
yavuz25
I changed [QUOTE = muratoner]. The result did not improve. [/ QUOTE]
remove the pole and insert reset then then
08.05.2020 16:32 # 7
ByHack
no need to sync!
