Help please
08.05.2020 19:19 # 1
Engin ASLAN
Hello friends, I have the 2008 model diesel 308, I am very happy with my car. Headlights are flashing by themselves when the ignition has been off for two days alone. ...
08.05.2020 19:19 # 2
Canberk35
Firstly, get well soon. There were a few friends in the forum who faced this type of wiper problem. As far as I can remember, most of the problems were due to water leaking into the BSI department, BSI getting wet, and water entering the insurance department. There is probably a similar problem with your vehicle. I think the problem will be solved by checking BSI section for wetness and possible non-contact.
08.05.2020 19:19 # 3
GokhaN
As canberk said, these are the brain problems.
08.05.2020 19:19 # 4
talip206
I think it's about BSI. There is only one more case. Short circuit anywhere can mislead the brain. I had read in the forum that a friend was doing this kind of thing because the short circuit on the rear wiper motor affected bsi. But the important thing is to find it
08.05.2020 19:19 # 5
Engin ASLAN
Well friends flashing the headlamps when the ignition is off is related to my brain Engin ASLAN 2015-06-14 14:02:06
08.05.2020 19:19 # 6
ismailkaya
the headlights are on when the ignition is off, as if there is a problem in the joystick controls, but the wipers should not work, only the headlights are blinking.
08.05.2020 19:19 # 7
Canberk35
Almost every system in the vehicle is in communication with BSI. Including headlights and wipers. Vehicles that already have a headlight and wiper sensor (or in any package) have to be in contact with BSI in order for this system to work. The fault is related to 99% BSI.
08.05.2020 19:19 # 8
Engin ASLAN
This bsi gives the original price of 850 TL. I wonder if there is another solution.
08.05.2020 19:19 # 9
Canberk35
The price given is normal for zero BSI. But it would be very easy for me to say that a bad one will be installed. 307 BSI failure is usually caused by water entering through the left-hand grille on the windshield. The water coming in harms the BSI brain. First of all check whether BSI has problems such as wetting, rusting and rotting. Most problems are solved by drying BSI or cleaning with rust remover sprays, contact sprays. If your master says "this BSI will change" directly without any recovery, I recommend you take the vehicle to another master. After all, this is not a cheap piece of 50-100 pounds.
However, if communication problems continue in the vehicle, getting BSI out of the climbers may also be an option. They will probably ask for a price of 400-450 TL.
08.05.2020 19:19 # 10
Engin ASLAN
thank you thank you let's see tomorrow I will take it to another master thank you again
08.05.2020 19:19 # 11
rebel_43
As the friends say, there is a brain malfunction, but zero parts are not required.
