help please (206 gti)
08.05.2020 17:53 # 1
ARAL
hi everyone. Although the engine is newer, it smells black smoke. Shortly after the engine was built, the injection made problems and instead of spraying the fuel, it was washed inside the engine.Is it possible to mix oil with fuel, so it throws smoke.And my car started to sound like diesel. Although it has been replaced with the new original, the vehicle still cannot hold the idle and stops. aggressor 2013-08-22 15:33:38
08.05.2020 17:53 # 2
yusufcaglarakarsu
If you write 206 Gti in parentheses in the title of the opened topic, you can reach the result more quickly.
08.05.2020 17:53 # 3
volkanC2
My 1.4 gasoline 106 car was burning oil, too much, but there was white smoke, not black smoke. I don't know if it is the same thing, but let me state it as an example.
08.05.2020 17:53 # 4
ARAL
Thank you for your help, Mr. Yusuf.
08.05.2020 17:53 # 5
EmSul
Probably the engine of the vehicle is not properly built and it looks like you will have to have it done again. If the black is throwing smoke, it is already burning. The gaskets may be damaged.
08.05.2020 17:53 # 6
qqyyxx
I did not understand the black smoke phenomenon in the gasoline engine. it burns me off the gas, does it idle or start up.
08.05.2020 17:53 # 7
ARAL
Well, what is the estimate of Emsul Bey? If we look again.
08.05.2020 17:53 # 8
ARAL
[QUOTE = qqyyxx] I did not understand the black smoke phenomenon in the gasoline engine. it burns me off the gas, does it idle or start up. [/ QUOTE]
It is not clear at idle, it throws a lot but a little bit, but as it gets loaded into the gas, black smoke. more engine was built just 400km from the vehicle
08.05.2020 17:53 # 9
qqyyxx
If the engine has done troubled troubled work, ask for repair again or get a lane and have the master who knows the work well checked again.
08.05.2020 17:53 # 10
yusufcaglarakarsu
[QUOTE = aggressor] thank you for your help yusuf bey. [/ QUOTE]
This place is full of helpful good people Wink You're welcome.
08.05.2020 17:53 # 11
error
clearer answers will come if you elaborate on the injection problem.
08.05.2020 17:53 # 12
ARAL
Normally, I do not need to spray the injection, my fuel was injected like a non-sprayed faucet. Even the spark plugs were fueled. aggressor 2013-08-23 20:23:41
08.05.2020 17:53 # 13
Bunyamin.Kar
Black smoke is a rich mixture, that is, the result of too little air in the fuel, as you say, the fuel comes too much and the spark plugs because the spark plugs cannot burn and stop. There is a problem with the injectors or they made a mistake when installing the injectors.
08.05.2020 17:53 # 14
ARAL
Mr. Bey, thank you for your help. Well, could Bünyamin Bey be mixed with oil with too much fuel?
