help please
08.05.2020 17:12 # 1
efsanemurat
friends, I have been encountering a problem for a while, when I was driving, everything was normal, when I brake at 120 and above, stop and oil lamp sign was flashing at first, it doesn't sound continuously but sometimes it doesn't do for a long time. not just the oil lamp was burned, it came off immediately, then it came out a little bit, then everything is normal, but I tried this, I usually do it when I go for a long time and then start braking. What should I do between 80 I use this way & nbsp; I hope it won't be a problem
08.05.2020 17:12 # 2
efsanemurat
I am wondering why friends who do not know why please share information ....
08.05.2020 17:12 # 3
Serkan
Sir, oil pressure is decreasing, probably if the oil level is ok, you can do it from the oil filter, when was the last time you changed the oil filter and was the original filter you used?
08.05.2020 17:12 # 4
efsanemurat
date ...
08.05.2020 17:12 # 5
Barut
I had the same problem, if the oil filter is not original, it does it if you change the oil filter, the problem is solved, the master working in the peugeot service also told me.
