HELP PLEASE !!!!
08.05.2020 16:41 # 1
efsanemurat
hello friends playing in the back of my car, I have changed the shock absorbers 3 months ago, it has been happening ever since, especially on a slippery ground, while the folks are going with the summer tires easily, the back slips when I go even with the winter tires. the balancer has examined it, he said there is nothing, the car is going uneven on his way, he is playing back and forth constantly, if I go slowly, he starts to play the back immediately as if he is not playing the tires, the whole body is playing on the tire.
08.05.2020 16:41 # 2
kaan__
You said that the rot looked at the balancer but ... I don't know, but if it didn't check the rear axles with a computer, I would say if you have a little bend, I think it would be tossing
08.05.2020 16:41 # 3
istanbullu_3886
I've had any damage before from behind
08.05.2020 16:41 # 4
efsanemurat
there has been no damage he has never done before for the last 2 months
08.05.2020 16:41 # 5
safrane23
There are tires at the point where the balance arms are attached. They may be doing when they wear. "Wink"
08.05.2020 16:41 # 6
toga406
My vehicle 406 had a similar problem. rear tires master shook the gap & nbsp; It is noticeable immediately. There are
anti-roll bars on the rear wheels, so some models of peugeots also have rods on the rear wheels. 25 & nbsp; er changed from tl. 15 TL workmanship and result rod balance both front and back. result = PERFECT as if you just got it. tires wear, not expensive replace them both.
I felt that I was traveling over 100 like a wind blow. no problem anymore
08.05.2020 16:41 # 7
efsanemurat
I will do what you say as soon as possible.
08.05.2020 16:41 # 8
efsanemurat
friends, have any other ideas, I'm waiting for your help
08.05.2020 16:41 # 9
efsanemurat
actual
08.05.2020 16:41 # 10
osman_bora
I have 406 v-me in the rear rot shafts replacement sound & nbsp; No, I made a rotting pleasure, number ten.
08.05.2020 16:41 # 11
efsanemurat
I am waiting for your ideas and solution suggestions
08.05.2020 16:41 # 12
efsanemurat
friends went to the master again did not find anything 3 months ago I changed the shock absorbers, the rear shock absorber is out of him said, but I did not give much chance still I haven't been solved waiting for help
08.05.2020 16:41 # 13
efsanemurat
170 people have read & nbsp; but have no idea as if the forum is out of taste
