HELP PLEASE
08.05.2020 18:59 # 1
bedlowe
SELAMUNALEYKUM FRIENDS. I own a 106xn, my first car and its been a few months. The trouble in my car is not going on gasoline, the car is singing as if I pressed the gas, someone from the back pulls the car. The gas was constantly stopping while shrinking the gears, while I was pulling from 5 to 4, while I was pulling from 4 to 3, I was constantly stopping. I changed the automatic choke sensor, and took it to a carburetor master, thanks to the guy, he solved the problem I experienced in the gas. It doesn't stop at the gas right now. But the car does not go like I said in gasoline, shaking, singing. If I remove the socket attached to the brain and do not get any gas from gas, it will work well in gas, but it will not go when I get gas from gas. Some say gas is mixed with gas. some say the gas pump is problematic, some says the injector body is faulty. PLEASE HELP ME TESTED TOWARDS THIS PROBLEM AND I ARE ABOUT TO GO TO THIS .. RESPECT.
08.05.2020 18:59 # 2
xmen
When you take the car from gas to gas or from gas to gas, put the gas or gasoline after a few km of the button, just in the middle of the button. Just as they say, gas and gas may be mixing. the throttle setting is probably too low when changing gears. that is, because it does not get enough gas.
08.05.2020 18:59 # 3
muro_60
Does the carburetor have gaskets for gas adjustment?
08.05.2020 18:59 # 4
bedlowe
vehicle single point injection friends. I changed the gas setting to stop when changing the fites in the gas, I think it has improved a bit, I think it will need to be increased a little more. If I take the kicking of the gasoline to the peugeot service, can I find the fault? And what would it cost to detect this malfunction?
