HELP PLEASE
08.05.2020 20:04 # 1
pugmylifee
friends, hello, I'm about to eat my head.
I have 206 1.4 cars, the car clicks the gear to the gas at low revs, a click sound is disturbing. When I pull the handbrake and put it in throttle, the sound is heard in the same way.
thanks
08.05.2020 20:04 # 2
It would not be right to make a comment without listening to the vehicle. I can say two reasons.
1- It may be related to the steering pump.
It may be related to 2-valve adjustment.
08.05.2020 20:04 # 3
pugmylifee
Is it possible that it is from the transmission or engine ear
08.05.2020 20:04 # 4
EMRE_R19
If it comes when it emits gas and releases the gas, it may be an engine ear, but if it comes continuously at a certain constant speed, it will be possible.
08.05.2020 20:04 # 5
pugmylifee
He does it in low speed in 1st gear, generally it doesn't sound at high speeds, he does something at 1200 speeds and he has something to do with the engine.
08.05.2020 20:04 # 6
ggitaristt
When the steering pump turns to the end, it loads the engine.
Turn the headlights on or off without turning the steering wheel and load the engine a bit. If it is interrupted, you will eliminate the steering pump.
08.05.2020 20:04 # 7
pepecura
When the gas is put into gear, the sound that comes from the pressure pad and ball is thinking, when did it change?
08.05.2020 20:04 # 8
BOZKURT71
Can it be loaded into gas?
08.05.2020 20:04 # 9
pugmylifee
The pressure was 50 000 km to the pad, the different sound is coming from the gas to the pressure slightly, but there is a sound like knock but the service or something is not fully diagnosed.
08.05.2020 20:04 # 10
pugmylifee
When it comes to slow pressure, the sound keeps steady at 1200 rpm, click, click, knocks, I don't hear the sound or it doesn't come.
08.05.2020 20:04 # 11
pepecura
If I put it in gear and press the throttle and it is 50 thousand, I would worry if the car was a pressure pad.
