help peugeot parttner set! ....
08.05.2020 14:05 # 1
kahla
Hi friends, I am a new member among you. Our car is the original tape on the peugeot partner 2005 model car mp3 filter eco mode or something. I was too bored with this tape and made a adjustment like this.
1.pıoneer deh-1100mpb
2.sansuı cs-w5030p 1300 watt box bass double coil
3.harward hr- 508a 400 watt amplifier
I think this system is enough for my partner, I wanted to get your opinion on you.
Let's come to the main subject.
2. Do we have any other operations related to cables in the second bid, such as insurance and banner. I would be very happy if you could help. Thanks in advance.
08.05.2020 14:05 # 2
CIHANGIR_DONMEZ
IF THE MATERIALS ARE READY, THE COR CORSA COIN ATA AUTO FUNCTIONER REQUIRES THE INSULATION REQUIRED CABLE TOWING DOESN'T INSTALL YOU LIKE NEW VEHICLES OLD LANGUAGE.
08.05.2020 14:05 # 3
kahla
WHAT WILL WE PASS THE WIRE FROM THE BATTERY, I WANTED IT.
08.05.2020 14:05 # 4
CIHANGIR_DONMEZ
[QUOTE = kahla] WHERE WILL I PASS THE WIRE FROM THE BATTERY I WOULD LIKE IT. IT DOES NOT PROCEED AS PUNCHING THE CAR. [/ QUOTE] GENERAL UNDER STEERING WHEEL IS THE MOUNTED HOLE IN NEW VEHICLES IF IT IS ALREADY IN THE OLD VEHICLES :) AIR BILE GIRIO NATURAL VENTILATION "LOL"
08.05.2020 14:05 # 5
kahla
Is it from under the steering wheel from the inside or from the engine through the steering column?
08.05.2020 14:05 # 6
kahla
When pulling the cable from the battery to the amplifier - they touch the cable with the bio to the car's casing.
08.05.2020 14:05 # 7
IBRAHIM
& Nbsp; & nbsp; & nbsp; I have enough auto electricity information, even if my friend is small, the electric parts of the peugeot cars will be different, I think it is a signal to the brain. ; & nbsp; & Nbsp; If the answer to the question you are asking is the (+) pole is placed directly from the battery, the amplifier is (-) the pole can be taken from the chassis.
08.05.2020 14:05 # 8
hasimayaz
You will connect it to the front (inside the hood) fuse box with the connection from the battery. Place this point on the fuse for audio installation immediately. Never use the feeding sheet that came to the original tape. Otherwise, BSI lights up. Insert the + cable from the fuse box through the same hole as the cable for the hood release latch. You may need to cut the gasket at this point a little. When you put back the gasket, make sure that the cables are adjusted so that they will not be damaged and that they are waterproof. For (-) you can use any chassis point on the trunk side.
& nbsp;
Pull a parallel from the blue wire in the original unit socket to trigger the amplifier. you will attach it to the amplifier's trigger input.
& nbsp;
08.05.2020 14:05 # 9
kahla
No we will get a direct (+) battery or a cable coming from the battery to the fuse box.
08.05.2020 14:05 # 10
kahla
I am very afraid of bsi's burning, I have a familiar electronicsman, I think to have him put it on. What is the most important point? Will the cable be pulled from the fuse
I am asking them ....
08.05.2020 14:05 # 11
ErkanKurnaz
my dear brother will be taken from the battery + connection will be like this. (Black wire) & nbsp; You can check the link below in
more. may not be enough for a complete assembly but at least you will have an idea
Extracted from
control item.com
ErkanKurnaz 2009-09-23 20 : 13: 44
08.05.2020 14:05 # 12
kahla
SAOL BROTHER THANKS
