Help over 306 lpg consumption
08.05.2020 17:32 # 1
alonedark
hello friends 306 1.8 8v my car consumes more lpg on average 100 km per 14 15 liters I use the car too hard, I am not using it very much. > 2013-04-25 10:56:30
08.05.2020 17:32 # 2
salihata
[QUOTE = alonedark] hello friends 306 1.8 8v my car consumes more lpg. It is about 100 km per 14 15 liters. I use the car too hard. I am very happy to use the filters, injectors, spark plugs and spark plug cables, but the fuel still has not decreased help please cool my car [/ QUOTE] < Have you changed the div> Lpg filters? What is your lpg brand? In my car, too, there was a lot of consumption, and I changed the lpg filters (40 lira) as well as gas adjustments, lpg filters should change every 10,000 km. If you have changed, have the gas leak checked and if you do not have a leak or gas setting, the problem seems to be solved.
08.05.2020 17:32 # 3
alonedark
yes changed atiker fas there are gas adjustments to the vehicle many times, no kacak but the result is the same
08.05.2020 17:32 # 4
ZP105
GAS ADJUSTED LOCATION DEGISTR IF THE SETTINGS FOR LOW COMBUSTION ARE CLEARED, IT WILL COME UP IN THE PRESSURE THE SETTINGS HAVE COME IN THE PRESSURE, THE NORMALE IS FROZEN AT THE PRESSURE AND THE VEHICLE WAS COMPLETED TO 10-11 LITERS WATER AND 8.8 LITER CITY AND BNM VEHICLE 2.0 16 V
08.05.2020 17:32 # 5
samet206
After replacing the filter injectors, spark plugs and spark plug cables, I recommend you to make a gas adjustment if there is still a lot of fuel consumption.
08.05.2020 17:32 # 6
salihata
[QUOTE = samet206] After replacing the spark plugs, spark plugs and spark plug wires, I recommend you to make gas adjustments if you still have a lot of fuel consumption. I agree, if you have changed everything, if you can not find a solution, replace your gas player.
08.05.2020 17:32 # 7
alonedark
I made it in different places on the gas setting many times, but the result is still not a problem on the same computer
08.05.2020 17:32 # 8
_ali_
If you use it in gasoline and look at it, there may be another engine problem if there is more than normal consumption.
Also, 8.8 Lt was very good for the city in the 2.0 engine.
08.05.2020 17:32 # 9
alonedark
friends I changed all the filters again, I made the lpg setting, I changed the spark plugs and cables, and finally I changed the ignition coil today I went to Istanbul, got 270 km destroyed, I calculated 11.6 liters of lpg on the long road, I did not find the reason why I consume too much on my vehicle, help me and continue to shake at low revs. when running, the engine is running very jerky on gas, the situation is normal & nbsp;
08.05.2020 17:32 # 10
alonedark
I did not spend 100 kmh on my way to and from
08.05.2020 17:32 # 11
alonedark
Someone who has the idea
08.05.2020 17:32 # 12
Aziz
I wonder if you are getting the gas from the shell :) I witness my vehicle is 200 km and the shell gas is running out at 90 km. gif "border =" 0 "alt =" LOL "title =" LOL "/>
08.05.2020 17:32 # 13
pierson
lpg filling area is visible on the back of my vehicle ... it didn't appear at first, but now it looks obvious .. I guess the masters have been trained while I was getting the gas ... how would I not do it ... it makes me nervous
