HELP ON THE RIM :)
08.05.2020 15:10 # 1
FRIENDS FIND THE BITANE WHEEL WHEEL I WOULD LIKE TO BUY 16 INCHES BUT I WOULD RECEIVE THE PERSONS WHICH ME TELLED NO BIMS.
CAN I TAKE A CHEAPER NUMBER AFTER THIS Bijons, Can I Find A Wheel According To That Wheel ...
08.05.2020 15:10 # 2
The rims of each rim may not be the same. so you should research because they won't be each other. I can't say anything about whether you can find it or not ... I wondered how it was a rim ??? the cecol 2011-03-16 09:29:56
08.05.2020 15:10 # 3
xdesign
You need 16 studs. Look at the publishers My guess is about 40 TL.
08.05.2020 15:10 # 4
peugeot original rim multi-spoke gti rim ..
I got the deal with the man but he says they don't have studs ..
Can I find every tire rim so expensive?
08.05.2020 15:10 # 5
hasretgonul
I guess it does not hold more than 40-50 liras, take your wheels to a good master when you get them so that you do not give the wrong stud, take your studs and assemble them. the possibility of not obeying
08.05.2020 15:10 # 6
I want 50 liras from the man.
you say 70 lira or something that is not cheap ...
08.05.2020 15:10 # 7
xdesign
We did not say 70, we said 40 :)
08.05.2020 15:10 # 8
MemoTech
I do not open a new topic, the same question is counted;
For the 206, the bolts of the 14 "Sheet Rim 15" 206 would be the GTI 5-Spoke Wheel ?
08.05.2020 15:10 # 9
GokhaN
[QUOTE = MemoTech] I don't open a new topic, the same question is counted as mine;
There is no need for high risk of cutting the bolts, and it will be too short to hold on to the greatest probability. long wheel bolts are essential in the original wheel bolt setting.
08.05.2020 15:10 # 10
MemoTech
I understood thank you. Do you know what the length of the original stud is?
08.05.2020 15:10 # 11
MemoTech
Does anyone know the length of the 206 GTI wheel bolts? Look, I open a new title :))
08.05.2020 15:10 # 12
Editor: Error Koliva 2011-03-18 20:58:57
