help on my way
08.05.2020 15:03 # 1
fahrikem
When I started running with my pejo 206 after I bought gasoline, the car did not work. The indicator lights were lit without too much. When I pressed the starter, click sounded.
08.05.2020 15:03 # 2
bydennis
I will have trouble with the charging dyno at the weekend.
my vehicle is 106 gti
When I run the car, the battery light was on and there was a yellow light, I do not know what light it is.
08.05.2020 15:03 # 3
fahrikem
After reinforcing the battery, I traveled for 5 km, I came home, stopped the car.
08.05.2020 15:03 # 4
bydennis
I think the problem is on the battery but there are many more experienced friends here. the dinomonun
08.05.2020 15:03 # 5
peugeotefe
If the vehicle stops working, remove the plus part of the pole head, there is a problem with the motor charging dynamo as soon as it is still working, it is either from the battery or there is something that draws electric current in the place.
08.05.2020 15:03 # 6
g-demir
[QUOTE = peugeotefe] If the vehicle stops working, remove the positive part of the pole head, there is a problem with the motor charging dynamo.
Super logic! must try ...
08.05.2020 15:03 # 7
metin
I guess he might be missing a pulley, which is one of the chronic malfunctions. but if 106 is different I don't know.
08.05.2020 15:03 # 8
fahrikem
Yes, the problem came out of the battery, the master charge dynamo was giving the normal level of volatility, but the battery was defective changed, but since the battery was removed from the pole, the tape started to ask for a password.
08.05.2020 15:03 # 9
Muhammet CAKIR
Come on, good luck.
