Help on audio system (Solved)
08.05.2020 16:55 # 1
Serkan
Friends I bought an audio system usb converter, I activated the cd changer from the service, I plugged the device into the cd changer input, the socket just sat down, but the device did not work, I am waiting for your help if there is any information about the subject, my tape 2004 model rb3 cassette player
I added in the picture friends two in the picture there are black wires, I did not find a place to attach them,
Serco05 2012-07-26 13:05:50
08.05.2020 16:55 # 2
Alicilik
Hodja, you have to look at it by trial and error.
Check the cables, even a little contactlessness may cause it to stop working.
Some converters have a button in between. This button acts as a switch to connect to the cd changer at any time. Check it out if it's there.
Make sure the tape is switched to cd changer.
Insert low memory memory format memory and discard music
08.05.2020 16:55 # 3
Serkan
I tried every way, I couldn't get my teacher to work on it.
08.05.2020 16:55 # 4
pug206
The construction problem is solved as soon as possible.
08.05.2020 16:55 # 5
istanbullu_3886
Do you try to remove songs from files, try one by one and check your format, I think
08.05.2020 16:55 # 6
Serkan
I tried turan brother songs, I changed it with SD card and USB memory, I tried to understand the empty cables in the picture, I remember if you had any empty cables.
08.05.2020 16:55 # 7
pug206
There is a mode button on the end of your vehicle's radio arm, I think it will be try.
08.05.2020 16:55 # 8
taskin
I have been using it for about 1 year. I installed it, I had it turned on the service. You bought one of the few pins. There is an 8-pin one and there is a cd bank key on the tape. there is no need for a special operation that is already sitting & nbsp; behind the tape. & nbsp;
08.05.2020 16:55 # 9
pug206
I think the problem comes from its introduction
08.05.2020 16:55 # 10
Serkan
[QUOTE = taskin] I have been using it for about 1 year. I installed it, I had that mode turned on in the service. You have bought several pins. There is an 8-pin one and there is a cd bank key on the tape. We have already looked at the back of the tape with & nbsp; there is no need for a special operation. does not pass
08.05.2020 16:55 # 11
nkre51
As far as I know, these do not happen to
rb3 or rd3s
& nbsp;
fits peugeot 207s
& nbsp; rb3s need connectors such as connects
mine is rd3 cd player
I opened the tape inside the connection, I made the connection to the circuits again it wasn't
but I saw friends who made the inside of the tape
but the sound quality was not good
08.05.2020 16:55 # 12
Serkan
[QUOTE = nkre51] As far as I know these are not
rb3 or rd3s
& nbsp;
fits peugeot 207s
& nbsp; rb3s like connects intermediate apparatuses are required. but the sound quality is not good
For rd3, separate apparatus for rd4 is sold. br>
08.05.2020 16:55 # 13
alper0771
I ordered it from the net today, but I did not activate the cd changer, I hope that I do not have a problem ...
08.05.2020 16:55 # 14
Serkan
Guys, now I have plugged the device back in and tried it again, but when I plug the phone into the USB port of the device, it means the phone is charging, the device comes with electricity, I activated the cd changer from pp2000 before I bought the device.
08.05.2020 16:55 # 15
istanbullu_3886
my 5s cd player was defective, but it was activated, my hex was switched on after a few attempts in mine.
08.05.2020 16:55 # 16
Serkan
I went to the place I bought today, we tried on another device but unfortunately we could not run it had to return
08.05.2020 16:55 # 17
KenBlockJR
I will tell you the problem. When connecting the vehicle to the computer, it must be activated from 2 places. & nbsp;
1) from the user options. 2) via the brain menu. most likely the active person has only activated from customer options. & nbsp;
Activate from the
brain tab will work 100%.
KenBlockJR 2012-07 -25 13:46:07
08.05.2020 16:55 # 18
Serkan
Yes, my teacher was active from one place Are you sure that there are 2 places?
08.05.2020 16:55 # 19
KenBlockJR
[QUOTE = Serco05] Yes, my teacher was active from one place Are you sure that there are 2 places? [/ QUOTE]
Yes absolutely. I was just giving it back. Then I called the friend from the authorized service and explained the situation. We introduced it in 2 minutes. :)
08.05.2020 16:55 # 20
Serkan
Is your vehicle a model with a cassette player?
Page : / 3
