Help on 2 topics
08.05.2020 14:56 # 1
300yedi
good night friends 1 week ago, there is water in the abs and diesel filter every two days, but the diesel filter water lamp is immediately on and the abs is on continuously.
Question 1: Why can abs fault have repair, is it too costly or is it necessary to buy new abs sensors or something?
Question 2: The diesel filter has been 10 or 12 thousand kms. Is it necessary to change the filter or do I get water from it?
I am waiting for your help already thanks
08.05.2020 14:56 # 2
I can answer the 2nd problem. Diesel filter changes every 45000 and not 12000.
08.05.2020 14:56 # 3
oguzhan29
your abs may be broken, they are constantly burning or they can add water to the diesel, injectors can also be damaged.
08.05.2020 14:56 # 4
300yedi
There is water in the mozot filter, it looks like it ends up. Is it possible to remove the water from the filter?
08.05.2020 14:56 # 5
oguzhan29
The brothers either clean it or replace it, but the place you buy diesel adds water to the diesel.
08.05.2020 14:56 # 6
Where do you buy the diesel
08.05.2020 14:56 # 7
300yedi
I always get from the sheldle. I always get the same gasoline just out of the city. I bought it from bp 1 time engine malfunction lamp lit up and I don't take it again from bp
08.05.2020 14:56 # 8
The bp and the shell are the same or whoever says, I say opet there is always water behind.
08.05.2020 14:56 # 9
Ozgur
OPET PO RECEIVES ALREADY FUEL
08.05.2020 14:56 # 10
MaximuS
I can't say anything about the first question, but the diesel filter changes every 40,000. But if you have a problem, change it. it is not such an expensive material anyway; would be comfortable for ...
08.05.2020 14:56 # 11
ali oncu
I think that there is water in the diesel, that warning, so I can relax my head if I say I have power.
08.05.2020 14:56 # 12
oguzhan29
In other words, there is water in the diesel, the first question is either from the customer or it is useful to show that it has a malfunction.
