Help not stop on the road
08.05.2020 15:06 # 1
phaselispa
Hi guys, I changed the tires of my car. The first 1000 km was normal but now it is the place that I say does not stop on the road. It gives the air that it is constantly slipping while turning its bends. used a friend yesterday, said without asking the room, there is a strange reduction in handling. tires 205 40 grew on the 16th floor, why does this car give my watch that it will always slide? I wonder if there is a problem with my bends?
206 diesel vehicles here
08.05.2020 15:06 # 2
I don't think it will be related to bend iron ...
Because when the tire changes, nothing happens to the bend iron. I think it may be coming forward from the tire you use. Previously, I used a 306 xt with kumho ku31 ecsta spt 195 45 16 tires, and I was shocked. my car did not go like it. I slipped sweetly with my vehicle. I couldn't make sense of this situation, but I thought it was from the tires ...
It is also a much more convenient measure for 195 45 16 206 instead of 205 40 16. Keep in mind...
08.05.2020 15:06 # 3
What is the brand of tires, by the way?
Bad tire + bad ground conditions = Low grip
08.05.2020 15:06 # 4
Ozgur
I think it's definitely rubber.
08.05.2020 15:06 # 5
GokhaN
it is definitely made of rubber. I had kumho before 106, ecsta supra slipped badly in the corner and stood hard. Then I switched to goodyear f1 neither slip problem nor stop. In my opinion, the lower limit of the middle level dunlop should not be attached to the tire in all vehicles.
08.05.2020 15:06 # 6
phaselispa
friends now i came from industry. I bought the tires from Ankara, now I am in Antalya.
I took it to the familiar master, tested it really throws the back. He said to the rotcu before I went and looked at it. then i went to the master. to get them checked. There's no problem with that. I went to the tire man, he said, make the tires back, he said, the teeth at the bottom. The front is still standing behind because it is front-wheel drive. I did that too. No, don't you tell me when you're going with 70, he slips away.
Meanwhile, the tires are new. brand toyo tires dimensions 205 40 16.
I'm going to go crazy, there is still no solution. I wonder if I go to the service
08.05.2020 15:06 # 7
GokhaN
Toyo needs to keep moving about 2 years ago I used toyo proxes t1r was great. If the production date and tread thickness of tires are really reduced, it can. I think I heard that if the tires you bought were old tires, the toyolar hardened and lost their performance after about 2-3 years. Do not neglect the tire, buy a new one.
08.05.2020 15:06 # 8
phaselispa
The tires are already above the zero green strips of blue. I asked other tires, they say the same, the tires are good quality, no problem. I called the person I bought the tires tires says 2010 production.
08.05.2020 15:06 # 9
GokhaN
[QUOTE = phaselispa] tires are already on the blue green stripes above zero. I asked other tires, they say the same, the tires are good quality, no problem. I called the person I bought the tires says tires 2010 production. [/ QUOTE]
Then there is a problem with the vehicle. The Toyo are very good. If you find a solid rot-balancer, I would first tell him if he doesn't, take him to a service near somewhere.
08.05.2020 15:06 # 10
phaselispa
Nervousness.
08.05.2020 15:06 # 11
GokhaN
There is nothing that can not be resolved. Göz Kırpma
08.05.2020 15:06 # 12
phaselispa
No, I went to the industry, everyone looked, could not find the cvp of the problem. if they say it is okay but no The last thing we said is, let's make the spring with torsion and then look at it. but I don't think you will notice anything. We are not always driving in the twisty city on our roads.
08.05.2020 15:06 # 13
ali oncu
I don't understand how the new tire hurts so much? i wore 106ya kumho ecasta i was not satisfied at all 4 but toyo is good i wonder if i have production error?
08.05.2020 15:06 # 14
phaselispa
I called the guy I bought, there is no mistake they said in 2010 production they said. it is already written on it
08.05.2020 15:06 # 15
klemann
Toyo is a great quality tire in my opinion, not a cheap tire before anything. but kumho is also not a bad tire, my car has kumho ku911, 195/45/16. It goes very well if I enter the corner hard and sniff the gas in the corner. It's also great at braking distance. If there is a tire you know, I think you should go and try it. If it never happens, there will be no question mark in your head.
08.05.2020 15:06 # 16
mendirek
My tires are clean. front swings will change. The problem will be over 400 TL. or as if the tires are coming down, your car will blow up as if it will give you left and right. Take care of yourself
08.05.2020 15:06 # 17
phaselispa
They looked at the fiber, but they did not say swing. I know what to do
08.05.2020 15:06 # 18
Muhammet CAKIR
Well, brother, I got it 195 * 50 * 15. Incredibly, the road grip of the car has increased. If the brand has such a grip, you should be more in the car. Check the weather, check the weather, rot the balance of the tires. no one noticed, I can only say that it may sound like a neighbor, but if the tire size is not installed incorrectly, one is different, I think it is 90% tire.
08.05.2020 15:06 # 19
phaselispa
What does swing do?
08.05.2020 15:06 # 20
phaselispa
he has a friend gti let me replace him with tires let's see what happens. If the tire comes out, our 1500 TL
Page : / 2
