Help my masters :( my car has passed 3 thousand cycles
08.05.2020 16:07 # 1
Burak07
first greetings to everyone 2.ailem
My car started to go after yesterday after the maintenance of the spark plugs, oil, oil filter and air filter, my car started not to go. it doesn't bother me too much :( please help in advance thanks in advance "Don't
08.05.2020 16:07 # 2
EmRe26
Could it be due to single-nail spark plugs knka?
08.05.2020 16:07 # 3
Burak07
I don't know, buddy, it is a very annoying situation.
08.05.2020 16:07 # 4
metin
I remember that it should have nothing to do with spark plugs.
08.05.2020 16:07 # 5
EmRe26
I do not know if it was original text, but the spark plugs of burak before maintenance were double nails, the current spark plugs were single nails. This was the first thing that came to my mind.
08.05.2020 16:07 # 6
metin
[QUOTE = EmRe26] I do not know if it was original text, but the spark plugs of burak before maintenance were double nails, the current spark plugs were single nails. This was the first thing that came to my mind. [/ QUOTE]
& nbsp;
I think if the spark plugs have a problem, the car burns raw, misfire, 3000 cycles will be a dream. Since there is a problem with the filters and spark plug replacement, you can be right, since I do not give the possibility to the filters, the spark plug remains.
& nbsp;
is alone here. Another problem may be that the vehicle has failed during maintenance.
08.05.2020 16:07 # 7
34sea45
Didn't you change the fuel filter?
08.05.2020 16:07 # 8
bluee
you should have the air flow meter checked.
08.05.2020 16:07 # 9
Burak07
[QUOTE = 34sea45] Didn't change the fuel filter? [/ QUOTE]
no I haven't changed "Shocked"
08.05.2020 16:07 # 10
Burak07
You must have the [QUOTE = bluee] air flow meter checked.
so why did it happen suddenly after maintenance so it may have caused it "Shocked"
08.05.2020 16:07 # 11
OkaN
It doesn't have anything to do with spark plugs, but it may be from cables, if it is broken or something, it kicks off the vehicle already in my hyundai vehicle & nbsp;
08.05.2020 16:07 # 12
Burak07
[QUOTE = 34GH0111] it has nothing to do with spark plugs, but it may be from cables, if it is broken or something, it kicks off the vehicle already in my hyundai vehicle & nbsp; [/ QUOTE]
It actually kicks up, so when I first start the car, I go 15 20 mt. When I put it in 2nd or 3rd gear, it does not accumulate to the front first, it does not eat gas, and then it suddenly adheres to lap, but this event does not go into maintenance. there was before so nothing new
08.05.2020 16:07 # 13
It means that there is a malfunction, the engine protects itself software-wise. So it does not exceed 3000 cycles. An error may have been made during maintenance. It can happen even if a piece is incorrectly installed or not seated properly.
08.05.2020 16:07 # 14
Burak07
[QUOTE = Berkay] It means that there is a malfunction, the motor is software protecting itself. So it does not exceed 3000 cycles. An error may have been made during maintenance. It may be even if a piece is inserted incorrectly or it does not fit properly. [/ QUOTE]
I checked the spark plugs in the evening. I put it in the cutter where it was then I pressed it thoroughly on the main road & nbsp; I put it in the cutter 2-3 times if it was difficult, I saw 160 again as it improved a little later, and I think it happened.
08.05.2020 16:07 # 15
Engin Tepe
My Doorstep: D
08.05.2020 16:07 # 16
Burak07
[QUOTE = Engin Tepe] Doorstrap: D [/ QUOTE
brother any "Grin" did not open holes from below I support with my 2 * 2 like stone age car "Embarrassed" < br>
08.05.2020 16:07 # 17
Engin Tepe
Okay time: D
I put the water in the oil, my big lion is ready: D We could not fix the trapezoid on the steering wheel alone. His vision bothers me a lot.
08.05.2020 16:07 # 18
Burak07
[QUOTE = Engin Tepe] Okay time: D
I put the water of the oil, the big lion is ready: D We couldn't fix the trapezoid at the wheel. His vision bothered me so much.
what the trap is no ??? Thank God I am ready, I hope I'm waiting for the right hand 18, I will go to the industry and replace the bulbs in the bidet stop. >
08.05.2020 16:07 # 19
muzaffer
I have heard of double quotes and single quotes, and your probability is due to it, Pasha. But I did not happen to me, a friend had this problem I know from there in Opel Astra.
08.05.2020 16:07 # 20
Burak07
[QUOTE = victorious] I have heard of double quotes and single quotes in my case. But I did not happen to me, a friend had this problem I know from there in Opel Astra. [/ QUOTE]
I think and hope that it will improve day by day "Laugh"
