Help my 307 very urgent faulty vehicle .. |
| 08.05.2020 20:12 | # 1 |
1- Could the drainage be finished? 2- Can there be a problem in the transmission? (They say the finished gear may have peeled off. I called the master, he said he could wrap the bed and said playback, let me check the mon. The oil is full of water |
| 08.05.2020 20:12 | # 2 |
sonerkyl |
1-I think as if the press pad is dead and the thrust bearing is scattered. 2-Check the flywheel when the gearbox is removed. 3-why engine shakes the bed, car working valves hit the engine stops 4-your priority is my teacher. Baksı set and labor cost approximately 500 TL. If there is a suspicion from 5-engine, compression test is performed first.
